Reply 1000 of 5157, by gdjacobs
Wow, I didn't even click onto that. Logic controlled amp gain is neat, especially in an amp of that vintage. I'd probably clean any switch contacts just to be thorough, but no pots is a definite plus.
Reply 1001 of 5157, by cyclone3d
Not really dumpster find.. but I was given these:
i7-920
i7-4770
Athlon 64x2 6000 AM2
Phenom II 1090T
AMD FX-8150 (some bent pins)
Also got a gaggle of motherboards that came with them. Supposedly most of the motherboards are faulty. I will have to test stuff out when I get a chance.
The only ones I am not holding up much hope for are some LGA socket boards with bent pins. Not sure if I can fix them or not.
There was also some RAM installed in a few of the motherboards.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1002 of 5157, by gdjacobs
Nice gift.
Reply 1003 of 5157, by oeuvre
Marry that person who gave you that stuff
Reply 1004 of 5157, by cyclone3d
HAHAHAHA, ummm no. For one, I am already married. And for another, I am not gay.
Anyway, he is a friend that was getting rid of stuff he was having trouble with or possible just was not being used anymore and had already put it all in boxes to get rid of.
He knew I was looking for old computer stuff. And although this stuff is not near as old as what I was really looking for I am not going to turn down free computer hardware.
Will be getting some CRT monitors from him as well at some point.
YMF7x4 Guide
Reply 1005 of 5157, by Jade Falcon
Rank BANNED
BANNED
Might want to condenser becoming gay to marry him 🤣 might end up being worth wile.
off course Im joking.
Reply 1006 of 5157, by gdjacobs
cyclone3d wrote:
HAHAHAHA, ummm no. For one, I am already married. And for another, I am not gay. […]
Well, maybe you can have a bromance built around computer parts, then.
Reply 1007 of 5157, by oeuvre
Convert to Islam then you can have multiple spouses.
Reply 1008 of 5157, by brassicGamer
Phenom II 1090T
(some bent pins)
That on it's own is pretty awesome. Are any of the boards SLI / Crossfire capable?
Reply 1009 of 5157, by PcBytes
KCompRoom2000 wrote:
A few days ago, a neighbor gave us this Planar PL1700 LCD Monitor for free, It works fine although there's one minor issue - it makes a hissing noise when turned off, not sure if that's normal behavior for its kind or if there are dying capacitors on the circuit boards inside, haven't opened it up yet.
It might be okay. I have a Benq FP71G+ I got for cheap that does the same hiss.
Although, I also suggest open it up and check for badcaps.
Reply 1010 of 5157, by cyclone3d
brassicGamer wrote:
Phenom II 1090T
(some bent pins)
Yep, I know.
Most of the boards are SLI/Crossfire capable. Basically no low end boards. All of them are ASUS or Gigabyte.
I've already got higher end stuff in my main systems, but these make for some nice spares as well as some nice parts to maybe build a nice XP box. Basically I have waaaaay too much hardware laying around already and not nearly enough cases to put everything in. If I had about 5-6 more ATX cases and 3-4 AT cases I would be set for a while.
A lot of hardware passes through my hands and stuff I don't have any use for or I don't want and is not worth me selling, if it is good enough, gets handed down to people that need computers or have even lower end stuff. I'm a lot more careful now than in the old days when I would sell or give stuff away.
YMF7x4 Guide
Reply 1011 of 5157, by kode54
Not really a dumpster dive, and not really recent acquisitions, but still neat nonetheless. Grabbed these for $20 each from the local Deseret Industries thrift store, before it relocated to another city.
LaCie Electron Blue III 19", manufactured October 2001:
Dell UltraScan P780 D P/N 06271R 17" Trinitron, manufactured December 1999:
Reply 1012 of 5157, by xplus93
kode54 wrote:
Not really a dumpster dive, and not really recent acquisitions, but still neat nonetheless. Grabbed these for $20 each from the […]
Yeah,those are a serious find. Beautiful, sharp picture. Congrats man.
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
Reply 1013 of 5157, by Baoran
Someone had left a tower case in a dumpster with both side panels missing. There was a motherboard with dual cpus and a psu inside. The psu was dead when I tested, but the motherboard and cpus work fine.
When I first saw the case in the dumpster my first thought was that it was a dual P2 system, but when I looked more closely at home, they were both actually 450Mhz P3 cpus.
I don't have a picture of the case and the dead psu because I threw them away before I thought of posting here, but here is a picture of the motherboard:
The attachment 20170531_130526.jpg is no longer available
Not sure what I will do with it. There isn't much from that era that takes advantage of multiple cpus. One option is just steal one of the cpus from the motherboard and use it to upgrade my P2 300Mhz system to 450Mhz.
Reply 1014 of 5157, by Cyrix200+
I love dual cpu systems! You can build a nice dual-boot Windows 2000 / Windows 98 system with it for example. Windows 98 won't use the second CPU, but it will still be a nice Intel BX chipset PIII system. But even in Windows 2000 the second CPU will be of limited use...
Gigabyte made nice boards back then!
Baoran wrote:
Someone had left a tower case in a dumpster with both side panels missing. There was a motherboard with dual cpus and a psu insi […]
1982 to 2001
Reply 1015 of 5157, by MrEWhite
Well, that solves half of that issue 🤣
Reply 1016 of 5157, by oeuvre
Wow, those Dell Ultrascan monitors take me back. Those were great. I had a P990 but ran out of space for it so it had to go 🙁
There are plenty of retro regrets with me.
Reply 1017 of 5157, by kode54
I almost forgot, the Dell came with a scuff in the coating on the glass, that obscures the image slightly. That whitish spot slightly below the center.
Reply 1018 of 5157, by Carlos S. M.
Ended getting two systems and a dead motherboard (not shown) from my uni, the first system is an HP XW4000 Workstation without the PSU which have an interesting videocard, a Matrox Parhellia-512 AGP, can't test the xw4000 because of propietary PSU missing, second system is an usual i865G mATX system. I can confirm both the Parhelia and the Geforce 4 MX4000 cards works
Specs:
XW4000
Pentium 4 2.66 ghz Northwood with propietary cooler
HP XW4000 motherboard
no RAM
Matrox Parhellia-512 128 MB
Maxtor 40 GB
Custom P4 system
Pentium 4 HT 2.8E Ghz Prescott with an all copper socket 478 cooler
Gigabyte GA-8IG1000MF
no RAM
Geforce 4 MX4000 (Gigabyte GV-N40128TE)
Samsung 80 GB SATA HDD
InWin 240 watt PSU
Reply 1019 of 5157, by TheAbandonwareGuy
Carlos S. M. wrote:
Ended getting two systems and a dead motherboard (not shown) from my uni, the first system is an HP XW4000 Workstation without t […]
Specs:
XW4000
no RAM
Maxtor 40 GB
Custom P4 system
no RAM
InWin 240 watt PSU
Is that HP a twin 6 pin? Adapters are like 3 dollars on eBay. More than worth it for a working workstation IMO.
Why did they take nothing but the RAM though? AFAIK RAM is usually the least valuable part in the PC. Probably doubly so for the workstation as I bet it accepts ECC memory which is always a fraction of the price of normal ram due to it constantly being mass retired from server farns.
