Reply 17520 of 58875, by Bancho
This arrived the other day. Guillemot 3D Prophet Geforce 256. Not sure if it is DDR or SDR.
Reply 17521 of 58875, by Kamerat
That's a SDR and the RAM might only be running at 150MHz instead of the normal 166MHz.
YouTube channel
Reply 17523 of 58875, by havli
Actually, I'm pretty sure this one is regular 32MB/128-bit. If the front RAM positions were populated, it would be a 64MB.
Reply 17524 of 58875, by Carlos S. M.
I think the best way to check is by running everest/aida32/64 or GPU Z and getting info. Also benching the card as well
Reply 17525 of 58875, by nforce4max
I don't have any doubts about that Guillemot 3D Prophet Geforce 256 being 128 bit as gimped versions of 128 bit cards will have the memory setup differently than this with the memory being front and back on only two 32 bit channels vs spread out over all 4. What is odd is they chose to put it all on the other side of the card vs the gpu side but none the less it is 128 bit.
Reply 17526 of 58875, by xplus93
Among other things I got a panasonic PCMCIA CD-ROM drive with the original DOS install diskette. Pretty neat to have I guess. I don't see myself getting a DOS laptop, but who knows.
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
Reply 17527 of 58875, by appiah4
Never knew there were 64-bit GeForce 256s.
I wonder if my SDR card is 128-bit or 64-bit..
Reply 17529 of 58875, by xjas
Got a minty Core 2 Quad Q9300 for my slow-burning hackintosh project, along with some other stuff. Ten bucks well spent!
It's replacing a Duo E8500 @ 3.16GHz, so I'm losing some clock speed, but I think the extra cores will be worth it for what I need it to do (audio & video editing.)
The attachment quad.jpg is no longer available
I wish I could upgrade my C2D Mac Mini with this instead, but Apple soldered in the CPU because of course they did.
Reply 17530 of 58875, by Kamerat
Second that (but the RAM could be running at only 150MHz as I said before, see next page), here's a benchmark of the Guillemot 3D Prophet. The 3D Prophet still beats a TNT 2 Ultra, while the 64 bit GeForce 256 doesn't.
YouTube channel
Reply 17531 of 58875, by Vincent_Vega_SA
Got one nice Compaq Armada 100s laptop with K6-2+, but without AC power adaptor. I will make one from other Compaq adaptor with DIY power connector...
Reply 17532 of 58875, by FuzzyLogic
xjas wrote:
Got a minty Core 2 Quad Q9300 for my slow-burning hackintosh project, along with some other stuff. Ten bucks well spent! It's r […]
That GUS (Max?) in the background looks more interesting and retro than the C2Q.
Reply 17533 of 58875, by xplus93
appiah4 wrote:
Never knew there were 64-bit GeForce 256s. […]
Is that a 64mb model?
Reply 17534 of 58875, by appiah4
No, it's 32MB.. AFAIK? Maybe I should check..
A big box of stuff arrived today.. Some of it was paid for, some of it was free gifts the seller threw in (I'll note the gifts).
A new-old stock AT Socket 370 motherboard:
Two Sound Blaster 16 Vibra CT2980s, I will likely sell off one.
STB Voodoo 2 12MB with cable
A slotket with a PIII 700MHz CPU in it
Two pins from the CPU fell off immediately as soon as I removed it, and won't POST. I binned it. I can't complain though, considering all the rest (including an Avance Logic sound card with an OPL3 clone) came as free gifts:
Reply 17535 of 58875, by jheronimus
Finally got a Roland MT-32 today! Cost me 160 EUR incl shipping. Came with the power supply and manuals, but no cables. I have the gameport to midi cable, but I'm not sure what kind of audio jacks this thing uses. It's an old model with no headphone output, and it doesn't have 3.5mm holes.
The attachment 2017-06-29 11.17.49.jpg is no longer available
I'll only be able to test it when I get back home, but I've already tried to power it on. It works, but it looks like the potentiometer for the volume knob is broken. The knob only works when I press on it pretty hard, and the volume goes back quite a bit as soon as I release the knob. How hard is it to replace/fix it?
In the meantime, can I change the settings using MIDI commands, like on a CM-32L?
MR BIOS catalog
Unicore catalog
Reply 17536 of 58875, by CkRtech
It is possible the pot just needs to be cleaned.
Reply 17537 of 58875, by appiah4
Yeah sounds like a bad oxidation issue to me.
Reply 17538 of 58875, by jheronimus
What's the pot?
I really hope so, but the seller sent me a video beforehand where the volume was at 100 (he didn't use the knob in the video, though). However, now if I push the knob and try to get to 100, it will roll back to 82 once I release the knob.
MR BIOS catalog
Unicore catalog
Reply 17539 of 58875, by appiah4
He probably refers to the potentiometer by pot.
