Reply 6040 of 31264, by TheAbandonwareGuy
- Oldbie
wrote:Unfortunately phasechange and ln2 are waaaaaaaaaaaaaaaayyyyyyyyyyyyyy out of my price range (my usual total income at the moment […]
wrote:Nice. You should throw a E8400 E0 stepping in there and see what it can do.
Do you have any plans to go LN2 or Phasechange?
Unfortunately phasechange and ln2 are waaaaaaaaaaaaaaaayyyyyyyyyyyyyy out of my price range (my usual total income at the moment is $30 - $40/month.) Plus I'm saving up for a new video card for my big gaming computer (my dual-1366 rig) some time soon.
I did also get one of my other chips to run well. I have a single core cedar mill celeron I got to run at 5200 mhz, but kinda pointless.
And then finally after "playing around" with the p4's I loaded up my best spare 775 chip for it a x6800 and playing with that. Turns out the multiplier being unlocked is almost completely useless on it. My x6800 won't do a single +1 mhz over 3905 or it won't even start up. But 3900 - 3905 is perfect and runs great. Unfortunately this x48 motherboard I have doesn't like any of my fast ddr3 I own.. I have a set of ADATA DDR3 (3x4GB) rated for 2000 mhz, and a 4x4GB set of Mushkin Blackline ram rated for 2400 mhz. Neither will actually run at all in it. The only ram I can get to work in this board is my set of 1GB DDR3-1066-ECC (not registered) ram from when I first got my file server some 4 years ago. Works in this thing but I only get 4GB ram for now. Maybe I'll try a set of kingston in it later. Kingston works in everything.
Is it possible Intel put an artificial limitation on the X6800?
