Reply 6080 of 30918, by vvbee
wrote:What type of DOS game are you writing? Which game is the remake based on?
Just a little game. Just some old game.
Today I got this Pavilion in the mail and I tore it apart, cleaned it, reassembled and upgraded it. Runs very nicely. More pictures + info here https://imgur.com/a/fAnCF
Decided to upgrade the hard drive in my iMac G3/600 to a 200GB HDD in place of the 30GB HDD due to lack of space for my video import from my camera, and I might attempt to run both Mac OS X Tiger and Lubuntu
16.04.2 LTS side-by-side if the Linux boot cd detects the rest of the storage.
Edit:
I successfully installed Mac OS X Tiger, and its affiliate updates, such as 10.4.11 update; now, I'm installing Lubuntu on the HDD since Linux detected the rest of the storage (128GB for Mac OS X, and about 64GB for Linux). Well, apparently, Linux won't boot since I found out only 128GB is the limit for the iMac G3, and the only option I have left is to shrink the partition for the Mac partition when re-installing Mac OS X Tiger.
Decided to oven bake some cards as it is summer and popped some rot caps on a Ti 4400, had to bake a Ti 500 as well because a previous owner ran it without a fan till it failed...
Finally got to setting up my Aopen AX53 (430HX) ATX board. Some random points.
1. Screwholes are not standard ATX. I believe the bottom half is actually Baby-AT. FML.
2. It came with a manual. Unfortunately, the manual jumper settings differ from what's printed on the board. Guess I'll go with whatever is printed on the board.
3. Put in a known working P166-MMX and 2x 16MB EDO. SIMM's use a weird plastic thing I've never seen before.
4. No power when using ATX power supply. Thought it was a dead board. Looked at manual. Apparently there was a jumper setting that allows you to select ATX or AT power source (what's etched on the board just says POWER ON/OFF). Jumper was stuck. FML. Had to pull out the ATX -> AT converter.
5. Powers on! Fortunately I have a Viper V550 PCI with a fan, so I have an idea when the board gets power.
6. Never seen this funky Windows 3.1 style BIOS before.
7. CMOS battery is unsurprisingly dead. Unfortunately its a soldered on Dallas RTC. Sigh. I think I have to put this guy back in storage unless I get a case with ATX and AT style screws.
My Compaq with a P166 has the same BIOS. It weirds me out.
wrote:My Compaq with a P166 has the same BIOS. It weirds me out.
I have a 486 with the same style BIOS setup. Surprised me a lot!
1982 to 2001
wrote:Decided to oven bake some cards as it is summer and popped some rot caps on a Ti 4400, had to bake a Ti 500 as well because a previous owner ran it without a fan till it failed...
I have a half dozen cards that need baked.
What procedure do you use when you bake?
The first on my list is a Quadro FX4500 512MB because it's good cannon-fodder.
wrote:I have a half dozen cards that need baked. […]
Why does everybody seem to go for baking cards? There are a whole bunch of other reasons why a card could fail. Also, smoke is bad for electronics, don't see how it could help 😜
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
I had a 486 motherboard that had that, and that was amazing to see that BIOS, which did look like Windows 3 with the layout, and the BIOS supports the use of either a keyboard or mouse.
wrote:wrote:My Compaq with a P166 has the same BIOS. It weirds me out.
I'm pretty sure BBISHOPPCMS World did a video on those bios. Not super uncommon if I recall correctly.
Tried making my own Voodoo 2 SLI cable.
Ended up first breaking the connector on a floppy cable, then after successive attempts cut a finger pretty badly while trying to close the connector after lining up the cable and gave up.
Looked at eBay and saw people are charing $10 for a glorified floppy cable. Lost faith in humanity.
I used a chair to close mine. I did put the connector under one of 4 of feets and I sat on the chair. Works very well ^^
That Windows 3.x like BIOS is AMI's famous winbios 😀
wrote:I used a chair to close mine. I did put the connector under one of 4 of feets and I sat on the chair. Works very well ^^
Just tried this. It bent the teeth and broke the second connector. I give up.
Haven't physically started on it yet, but here's my *pun intended* game plan:
-Make CF card "fixed mode" instead of removable, if at all possible. Got a SanDisk 8GB, so I don't know if I can even do that with this card.
-Install Windows 98SE onto CF card, put in my Dell OptiPlex Gs via IDE adapter
-clone old, slower Maxtor drive onto slightly faster, 40GB newer Maxtor drive I ripped from a Win2000 machine
-set it up to dual boot real DOS 6.22 and Win98SE
-somehow not lose my files and old games in the process
-do something with the Yamaha XG1000 card sitting next to my printer in a static-proof bag as it didn't sell on eBay even when I re-listed it. "IRQ Hell" currently has no free IDE slots left for it, and I'm already stretching my luck with the MIDI options as it is on that rig.
-copy all my aging floppy disks onto a USB stick and use them in a floppy emulator, especially my old dad's UpTime disk magazines. Those were awesome!
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
wrote:wrote:I used a chair to close mine. I did put the connector under one of 4 of feets and I sat on the chair. Works very well ^^
I built my own as well, I broke one connector but the second try worked. My experience is that some connectors open and close a lot easier without breaking than others. I used a small hammer carefully to close mine.
1982 to 2001
Removed a "heatsink" and thermal tape from one of my PC boards' cpus, applied proper paste and reattached the "heatsink"(code name: meager metal). Latter seems sub-optimal to me but I've got no replacement which fits the spacing between board and chassis.
The cpu is a nice one I haven't seen before(Am486 DX4-100V16BHC).
wrote:wrote:wrote:I used a chair to close mine. I did put the connector under one of 4 of feets and I sat on the chair. Works very well ^^
Ok, third time is a charm. The chair trick actually worked, finally.. I used a desk instead, but it closed shut. I'll be trying it when I have access to my MMX system next time. Wow, so super excited! I'll need FastVoodoo drivers to SLI two different brand Voodoo 2s right?
wrote:<snip>
Good to hear! Yes use the FastVoodoo drivers. Those driver overclock the memory a little bit, which caused problems with my Voodoo2's, so check that.
1982 to 2001
wrote:wrote:<snip>
Do I need an external utility to dial them back down to 90MHz?
