Reply 18980 of 58858, by Predator99
yawetaG wrote:
Predator99 wrote:
- some sort of ASUS PCI SCSI/Soundcard with a Vibra Chip
Hold onto this one. Several ASUS motherboards had optional proprietary SCSI cards that allowed the motherboard to boot from either IDE or SCSI (as opposed to only having SCSI boot with no devices attached to the IDE bus, like with regular SCSI cards), and this might be one of those cards. It will only work with specific motherboards, though.
cj_reha wrote:
That Asus SCSI/soundcard is made for the Asus MediaBus, an expansion they put on some socket 7 boards.
You are both right! Didnt remember this - I own such board: P/I P55T2P4S. Seems I can make a "double SCSI" out of it 🤣
The attachment IMG_7884r.jpg is no longer available
The attachment IMG_7886r.jpg is no longer available
Reply 18981 of 58858, by gdjacobs
ASUS had different revisions of Mediabus, so make sure your T2P4 is compatible with the card.
Reply 18982 of 58858, by lazibayer
It is. They both use Rev. 2.0 of the media bus. According to wikipedia, Rev. 1.2 and 2.0 ain't physically compatible with each other.
Reply 18983 of 58858, by boxpressed
Thought I scored a Quadro4 900 XGL for $15 shipped. But no display on boot up, and the fan doesn't work either.
Easy come, easy go.
The attachment IMG_0648.JPG is no longer available
Reply 18984 of 58858, by c0keb0ttle
Found this MusicQuest card locally for a very good price! It came with the box, but without the cable which I had to buy separately from Ebay, Still came to a very good price (<$50) in total.
The attachment mqx-32m.jpg is no longer available
I was using the (excellent) clone card I'd bought on AmiBay, but I can finally use a time typical card instead. 😀
Reply 18985 of 58858, by TheAbandonwareGuy
Easy come, easy go.
Maybe it's not getting power?
Reply 18986 of 58858, by bjwil1991
Easy come, easy go.
I looked at the caps and they look okay. Might as well check the caps, chips, and if possible, replace the fan since it might be seized up.
Reply 18987 of 58858, by keropi
Please update us at some point when you test games, I have read in the past that this 2in1 MPU design although great for music production introduces incompatibilities with games.
AFAIK this card is just 2 MPUs glued together with some extra functionality when it comes to channel managing (or something along these lines)
Reply 18988 of 58858, by Jade Falcon
Rank BANNED
BANNED
Easy come, easy go.
Whats up with the 3 pin fan header?
Reply 18989 of 58858, by ODwilly
Scrapped a HP CoreDuo laptop, bought an itx case and hp 479 itx motherboard to utilize the CPU in a mini media center setup
Reply 18990 of 58858, by bjwil1991
Jade Falcon wrote:
Easy come, easy go.
That's probably for hooking up a new heatsink that has the 3-pin header, which was common for CPU and system fans.
Reply 18991 of 58858, by Fusion
I picked up a PCI-E X800XT 256MB for 10 bucks and a AMD Athlon 64 3800+ system with 2GB RAM for 30 bucks. Makes for a killer 2004 era system. I always said to myself I wouldn't build a XP era system but here I am. 🤣 I'm trying to identify the motherboard but CPUZ hangs when loading the program. The mobo PCB is all black which makes it hard to read any text on the board.
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 207/207 - SB Live! 5.1 - Windows ME
Reply 18992 of 58858, by TheAbandonwareGuy
OG CoreDuo laptop should be saved when possible. Its the Socket 423 of laptops, short lived and under-rated.
Reply 18993 of 58858, by ODwilly
This one had a GeForce 7300, had coffee spilled on it and the video connectors were torn off the Mobo. Plus the caseing was shot to hell. I upgraded it to 7 and a 120gb back in 2012 and it ran as a daily until the other night. It saw a long hard service life and I'm happy the CPU is going to keep chugging along.
Reply 18994 of 58858, by gdjacobs
Is there an extant thread on MPU-401 compatibility? I'd like to more formally run my MOTU card through it's paces and compare it with some other, um, eccentric MIDI gear.
Reply 18995 of 58858, by TheAbandonwareGuy
Ouch. Dedicated GPU and all. But I agree, that thing was shot 🤣 even the rarest stuff is garbage beyond some point.
Reply 18996 of 58858, by meljor
Easy come, easy go.
had this a lot. It seems very hard to find a working ti4600 (Quadro or Geforce). It took me quite a few cards until i finally found a working one. Most of them did post but had memory problems.
Ti4200 is a very nice card as well and they are extremely easy (and cheap) to find and usually work in my experience.
Reply 18997 of 58858, by yawetaG
There is also another version of this that uses a regular PCI slot combined with specific features in the motherboard's BIOS. This is used by socket 7 motherboards such as the SP98N for Asus-made SCSI cards.
Edit: Come to think about it, that motherboard has integrated video and sound, so it's basically a SCSI-only version of the Mediabus. The PCI slot is a regular PCI slot. The specific SCSI card enables SCSI boot even with IDE devices present.
Reply 18998 of 58858, by c0keb0ttle
I'll try to test it. Do you know of any examples where it would not work properly?
Reply 18999 of 58858, by keropi
^ nope, don't know any examples... Try the "difficult" ones like gateway, wing commander, laser squad - maybe all that was just rumors and the unit is fine 😀
