First post, by MalcomYork
Hi people,
I'm trying to install Windows 98 SE on a new computer I build a few days back and getting the following error during the installation:
Message SU0013
Setup cannot create files on your startup drive and cannot set up Windows 98.
To give you a little bit of context, here are my build specs:
Motherboard: Asrock K8upgrade-vm800
CPU: AMD Athlon 64 3200+
GPU: ATI Radeon 9550
Sound card: Audigy 2 ZS
Hard disk: Kingston UV400 120GB
I was able to create the partition table with FDISK and format it with the FORMAT command as a FAT32 filesystem. I have no clue what this message means, but as my research tells, this could be a SATA controller problem/incompatibility with Windows 98.
Has anyone experienced this issue before?
Reply 1 of 13, by mrau
sata?
Reply 2 of 13, by MalcomYork
Yes, SATA SDD drive.
Reply 3 of 13, by MalcomYork
I was looking to set a legacy/compatibility mode for the SATA controller, but there is non. Could that be the problem?
Reply 4 of 13, by mrau
what i mean - sata does not work just like that to my knowledge, also there were size constraints
Reply 5 of 13, by MalcomYork
Well, as far as I know, the size limit is 128GB and the disk I have is only 120GB, so that shouldn't be a problem. Am I correct?
Reply 6 of 13, by mrau
32gb max
Reply 7 of 13, by MalcomYork
Is that limit for the filesystem where I will be installing Windows 98 SE?
Reply 8 of 13, by mrau
yes, and as far as i know you should be aiming much lower still to not get a slow filesystem
Reply 9 of 13, by Stretch
Put the SATA controller to "legacy mode" "compatibility mode" or similar in the BIOS.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Sound BlasterX G5
Reply 10 of 13, by Joey_sw
also known as "IDE mode", which is software compatible with win 98SE.
But some bios may provide AHCI mode only, which making it incompatible with win 98SE.
-fffuuu
Reply 11 of 13, by MalcomYork
This might be the case, because I couldn't find ant "legacy" options on the SATA controller.
Reply 12 of 13, by MalcomYork
Ok, so I've got my hands in a PATA HDD and was able to install Windows 98 SE. After the os installation I was able to install the chipset drivers, which I downloaded from via's website. The data ssd is still being recognized by the os.
Reply 13 of 13, by MalcomYork
FYI, I've changed the data controller to raid and Windows 98 SE installed flawlessly. I'm changing this to resolved. That's to you.
