First post, by Munwele
Hello, I have a Fujitsu Siemens Primergy F200.
This machine was not POSTing, thanks to some 13 failing capacitors on the motherboard. I have replaced them and it's working now.
All of a sudden, one of its PSUs won't work. I turn it on, powers on for a split-second then turns back off, like there's some sort of protection that's triggering. It was working before...
Anyway, I'm also encountering a problem with its tape drive, it won't eject. I press the eject button and the ready button blinks for 5 seconds or so but nothing's happening. It's like there's no cartridge inside (there is). In fact, that's what the HP software application's thinking...
Click the images below to view the full-sized images.
Caption: Software says there's no cartridge present, although there is.
Caption: The 'Device Self Test' and 'Connectivity Test' were completed successfully. I cannot perform the 'Read/Write Test', the software
thinks there's no cartridge inside 😵.
Caption: The software reports that a firmware update could be the solution to the problem I am having!
Two things. One: I've searched and searched for the firmware update. Not only does it not exist on HP's servers, I can't find it anywhere else.
Two: Funnily enough, the cartridge used to eject when the server was not POSTing!
Caption: Firmware update window shows that the latest is version is N26D (I have N23D).
Caption: A picture of the tape drive itself. You can clearly see that there's a tape inside 🤣.
I have found a video explaining how to manually eject the tape. https://www.youtube.com/watch?v=MZD6qC2AQSk&t=2m36s
I would really like to try the firmware update first, though. Does someone here have it?
Don't get me wrong, I am very willing to try the manual eject method, but I'd really like to update the firmware first because
if that works, I won't have to open the machine up.
