Reply 19080 of 58863, by Deksor
Oh nice !
I bought a dimond edge 3D few month ago but it was loose. I'm looking for pinouts for the PC and saturn game ports as well as games for it.
Can you (or anybody else) help me ? ^^
Reply 19081 of 58863, by gbeirn
Big box of stuff came today.
Highlights: GeForce 3Ti 200 that needs caps, 2 GeForce 2Mx, 2 TNT2 Vanta, TNT2 Pro , 128Mb maxtrox parhelia, 2 16 Bit ISA Intel LAN cards, Soubd blaster 16.
40+ cards total, all indidually wrapped in bubble wrap! 😀
Will take forever to test it all. All for $60 shipped.
Reply 19082 of 58863, by Cyrix200+
I put a low bid on this a while back, did not expect to hear from it again. Much newer than what I usually deal with, I don't think I have a fitting system for it yet...
5mkh8YMl.jpg?1
1982 to 2001
Reply 19083 of 58863, by senrew
Cyrix200+ wrote:
I put a low bid on this a while back, did not expect to hear from it again. Much newer than what I usually deal with, I don't th […]
5mkh8YMl.jpg?1
The dual pIII board in your signature looks fitting?
Halcyon: PC Chips M525, P100, 64MB, Millenium 1, Voodoo1, AWE64, DVD, Win95B
Reply 19084 of 58863, by Cyrix200+
senrew wrote:
<snip>
Isn't it a bit to new for that? If I Google it a bit the 1950 Pro was released in 2006 and the PIII-S 1.4 in 2002. I will investigate further!
1982 to 2001
Reply 19085 of 58863, by Jade Falcon
Rank BANNED
BANNED
Cyrix200+ wrote:
senrew wrote:
<snip>
I seen a user on youtube playing fallout 3 on a dual p3 setup with a newer ati agp card. Ran rather well given the setup.
EDIT
https://www.youtube.com/watch?v=IC5kd0lOXkk
Reply 19086 of 58863, by Cyrix200+
EDIT
Huh, now I want to do that too 😜
1982 to 2001
Reply 19087 of 58863, by TheAbandonwareGuy
Cyrix200+ wrote:
EDIT
Fallout 3 is based on GameBryo which is an upgraded version of Morrowinds engine so this makes sense.
Reply 19088 of 58863, by derSammler
ATI Sapphire X1950Pro, 512 MB (AGP)
ATI Sapphire X1550, 512 MB (PCIe)
Yamaha TG100
Reply 19089 of 58863, by Munx
Cyrix200+ wrote:
EDIT
Why not bump it up to Crysis? 😎
https://www.youtube.com/watch?v=VD1mSaGsgg8
My builds!
The Underdog - The budget K6
Reply 19090 of 58863, by TheAbandonwareGuy
Bought a clamshell case Dell Dimension 4500 for $10 monitor included.
A 17" 1600x1200 M782 Flatglass CRT. I'm more excited about that than the computer.
Oddly, the PC only had a Rage 128 Ultra 16MB in it. What that could drive beyond desktop at the monitors native I have no clue whatsoever. Odd mix of a bottom end configuration with the only upgrade being a ridiculously beefy WiFi card. I just hope the monitor works right. This would be my 16x12 CRT (actually, it would be the highest resolution monitor I have aside from my XPS Gen1 built in display)
Reply 19091 of 58863, by xjas
^^ CRTs don't have a "native" resolution, it could handle 1600x1200 but it was likely used at 1024x768 for the most part. The picture doesn't degrade if you decrease resolution like on LCDs so anything you put through it will look as sharp as it can do.
(Posting on my 19" CRT dual-head setup at 2 x 1280x1024 right now, heh.)
And the Rage 128 Ultra is a rather nice card, as we've been discussing in the other thread. 😀
Reply 19092 of 58863, by badmojo
What makes sense? Morrowind kills any PIII I've tried it on - a fast P4 is more appropriate if you want high frame rates.
Reply 19093 of 58863, by jheronimus
Is that your retro rig or your everyday machine? I have a bunch of dual and quadro head Matroxes, Nvidias and even S3s, but I could never figure out a usecase for even a dualhead build (I only do gaming on those machines).
MR BIOS catalog
Unicore catalog
Reply 19094 of 58863, by TheAbandonwareGuy
How is it nice? A DX6 part in a 2002 machine is ridiculous.
Anywhoz the computer doesn't boot. Motherboards green standby light comes on but it won't boot. Which is weird considering the thrift store I bought from said it turned on yesterday (although it was left out in the heat all day).
I switched the power supplies and I got the same result. Pulled all the addin boards and still no result. I suspect front panel failure since it's unlikely to be the motherboard based on available information. Does anyone know which pins are the power pins on this Dell FP connector?
https://imgur.com/a/ukmJQ
And I'm also not sure I like this M782 display. It seems to have very washed out color, although I must admit it's very sharp. It's definitely NOT one of the famed Dell Trinitron displays I thought it was. The search for the perfect gaming CRT continues I guess.
Edit: Sure enough it CAN display 1600x1200 at 60hz and 1280x1024 at 75.
Edit 2: but it has to be forced which means most games will fail with a render creation error even when forced to run in that mode which makes this monitor useless. Why would they not expose the maximum addressable resolution to the computer by default?
Edit 3: can't get the geometry perfect either. Bowing at the bottom of the screen and one corner isn't perfectly straight. Pathetic for a flat glass CRT. It doesn't have a very great options menus with which to fix said issues either. Its better at 1280x1024 than my two KDS/ProScan monitors though so I guess it may very well steal one of there spots.
Does anyone know how to make 1600x1200 a fully exposed resolution?
Reply 19095 of 58863, by xjas
It's a modern machine (well, a Core 2 Duo with a Radeon HD4850.) I use it for writing Octave code for my work at the moment. 😀
I have two 19" CRTs next to each other on a desk with a bunch of systems connected to them. The two monitors are independently selectable on separate KVMs, I can switch the right one between the C2D workstation or the primary output of a P233MMX or a 386/25. The left display can be the C2D, a Mac Mini, or the Voodoo card in the 233MMX. Or whatever else I need to temporarily plug into the empty ports on either KVM. OS/X on a big CRT amuses me.
Reply 19096 of 58863, by TheAbandonwareGuy
I've never found a CRT bigger than 17" in the wild. Once I get properly employed I intend to sink a few hundred into a good well known top end CRT like a 22" Trinitron and then at some point later buy another as a backup. Keeping myself well equipped in CRTs for the remainder of my life is certainly an active goal.
Reply 19097 of 58863, by senrew
I sincerely hope you have a strong back 😀
Reply 19098 of 58863, by TheAbandonwareGuy
It carries around all 350 some odd pounds of me. I doubt a CRT will be the straw that breaks it.
Reply 19099 of 58863, by probnot
I bought some floppies on kijiji:
The attachment YmcXCIx.jpg is no longer available
....lots of floppies
I was going to pick up an Asus A7V motherboard from the same guy, but turns out he had already sold it, but he did have something even neater!
The attachment 2sjlCfr.jpg is no longer available
Suntac 286-20Mhz motherboard from 1990...and it has an onboard Floppy and IDE controller! On a 286!
He also had some ISA/VLB video cards...which is just what I was looking for to upgrade my current 286 (though I think I'm going to use this motherboard in it too!)
The attachment uT0vn6b.jpg is no longer available
- 2x Trident TVGA8900D (ISA)
- ATI Mach64 (VLB)
And finally, picked up a generic ISA NIC at the thrift store. I'm not planning to network my older machines yet, but this is nice to have if I decide to.
The attachment Uh2SgXV.jpg is no longer available
