Reply 220 of 381, by matze79
if you have a non-working unit, please pm me if your led is just flickering slowly..
i will resend you a mcu.
Reply 221 of 381, by EdmondDantes
If you're still looking for a serial scrollwheel mouse, I just ran across one that isn't the one linked earlier:
http://www.ebay.com/itm/Microsoft-IntelliMous … vUAAOSwDrNZTySt
Also this guy claims his mouse is serial but the box is unopened so he's only going by what the box says:
http://www.ebay.com/itm/Mitsumi-Scroll-Mouse- … YUAAOSwSzRZUW2B
Anyway, I'm kinda confused as to what the product on offer in this thread is. Are you making/selling an actual adapter, parts to make an adapter, or just a how-to guide?
Reply 222 of 381, by elod
All of the above I think. I just bought the PCBs, will get the parts soon for one complete unit, the other boards will stay on stock.
Reply 223 of 381, by bestemor
Just an update.
Had issues with the first converter I received, as no mouse was actually working, i.e. no cursor movement.
Then recently I received a replacement converter, which now has proven to function like initially expected.
Apparantly the previous problems had something to do with a firmware issue (?).
(me having no soldering skills, nor with MCU-programming, I ordered a fully pre-assembled kit)
So, while testing various options/hardware with this new one, I now even got it to work with that ancient(1999) Microsoft Intellimouse Intellieye optical mouse I wrote about earlier !
(it is a dual USB-native, connected via USB->PS2 passive adapter)
- Another thing I've learned, is that changing mice while converter is powered makes it not work.
If I do that, I then will have to cycle the power to give the converter enough time to 'reboot' and recognize/acknowledge the new mouse... or something like that. Or turn off power before switching, same difference.
Reply 224 of 381, by matze79
i added the project to hackaday io:
https://hackaday.io/project/27575-ps2-to-rs23 … mouse-converter
Reply 225 of 381, by feipoa
To confirm, are these now being sold with the option for a fully assembled unit?
Reply 226 of 381, by cliffclaven
I'm tempted. I always found those very comfortable to use.
Reply 227 of 381, by matze79
199.08 KiB
164.46 KiB
201.8 KiB
Finally i found some time to complete my multi i/o setup.
Reply 229 of 381, by matze79
i already ordered new pcbs.
it will take at least 8 weeks.
Reply 232 of 381, by feipoa
konc wrote:
For anyone interested in KVMs, it works perfectly well with a Level One KVM-0411
Thank you for providing this information. Did you try up to 1280x1024? Any lag?
Unfortunately, I'm unable to find any of these for sale. Looks like they were marketed in Europe.
Reply 233 of 381, by Tim1075
Perhaps we can make a sticky list of known working kvm switches? I am using an 8 port Compaq KVM switch but unfortunately there is too much lag 🙁
Reply 234 of 381, by feipoa
+1
Too much lag using my IOGEAR MiniView GCS614A (4-port w/audio)
Reply 235 of 381, by konc
No, not that high. But in 1024x768 (max of my 386's ISA VGA) in Windows 3.1 feels OK for normal GUI stuff.
I don't play serious games utilizing the mouse as the main controller on this machine (was there anything anyway?) so my experience with the adapter is limited to only point & click in GUIs or adventure games, where the adapter does fine. Even if there is a lag it doesn't really hurt for these tasks and goes by unnoticed.
Reply 236 of 381, by matze79
Hopefully this can be fixed.. also have now a new KVM with this issue 😳
Reply 237 of 381, by feipoa
Have you been able to pin-point what characteristic of the KVM is causing this lag? Like a sampling issue, or there being a sort of check the KVM is doing every x milliseconds? Considering that all PS/2 to serial protocal converters I've tested have had this issue (about half a dozen), chances are good that it is not something trivial to fix on the side of the protocal converter. I suspect the issue resides in a firmware or hardware hack for the KVM. I hope I am wrong.
Reply 238 of 381, by matze79
Not sure as i also have a Commerical one which has the Same issue too 😒
someone suggested to rise the clock speed of the mcu and recompile firmware, but i don't think this will fix it.
Due do its some kind of timing issue. Had no time to try it out.
i also will do another batch of pcbs 😀
