Received more PSX goodness: a SCPH-7502, two SCPH-5502s with sticker jobs, a SCPH-9002 (not pictured), a PSOne SCPH-102 (all modchipped), some original controllers, two Logic3 Justifier/GunCon-togglable lightguns, the PS2 IR receiver dongle, some cables (A/V, RGB SCART, SCART with breakout box), and a couple of games! The blackish 5502 came with a half-broken CD drive so I'm waiting for a new KSM440-ADM optical block for it. The 9002 is in almost perfect condition, as cool and quiet as a PSX can get while playing. They are all being thoroughly cleaned at the moment, one by one 🤣
Also got a rev 1.1 XBOX classic (Samsung drive) for dirt cheap. Came with the original Microsoft IR receiver on the fourth port. It powered on automatically when plugged and the front panel buttons weren't working. It had issues due to the clock aerogel supercap leaking electrolyte all over, destroying some traces. The first step was to get these lines reconnected with wire, as per this guide, to get rid of the front panel/power problems. Now the DVD drive needs some cleaning, as well as its rubber belt, since most of the time the tray refuses to open, and the last step will be a softmod or a TSOP flash, then a HDD replacement.
Stojke wrote:Its not like components found in trash after 20 years in rain dont still work flawlessly.
