VOGONS Driver Library
Reply 560 of 1658, by appiah4
Could I please have an account?
I have drivers I would like to contribute.
Reply 561 of 1658, by gerwin
SquallStrife
It is not really important, but the text line-height is not entirely proper. Text can overlap the text below it. It has always been that way. I think if you just remove line-height styles it should correct itself. Using Firefox here.
Reply 562 of 1658, by Paralel
SiliconSoft SoundJr. Windows 3.1/95 Driver & Test Program
Drivers provided by the developer for the SoundJr. parallel port sound hardware for Windows 3.1/95, as well as a test program for determining if the hardware is installed and functioning correctly
Reply 563 of 1658, by 33oldnew
Hi
1. SOUND UTILITY for COVOX - Package used to adapt the games and other software to work with analog-to-digital COVOX. Allows multiple programs to play a sound using the COVOX.
2. Window Sound Driver for COVOX on LPT1
Use with care, preferably on the copies
The description is in the Polish language, but that's not a problem to use the translator.
The attachment Covox-18P.zip is no longer available
Reply 564 of 1658, by xjas
Hey Squall,
I PMed you a while ago - could I get upload access to Vogonsdrivers? I have some sound card drivers (ATI Stereo F/X CD, rescued off my own floppies, currently not extant on the internet(!)) and a few other things (VR stuff, "lost" video utility for the original Asus eeePC models, etc.) I'd like to share.
On that note, all the early beta drivers that support the Oculus Rift DK1 have been wiped off Oculus' website (as I feared would happen!) I have my own archive of a lot of these drivers, exactly as downloaded from Oculus (installer untouched.) Should they go up on Vogonsdrivers? The DK1 isn't compatible with anything they currently host on their website, so if you're trying to run one you need these.
Reply 565 of 1658, by Drill_Sergeant_CH
Hey Guys, hi Squall. Need access for driver-cd upload:
I purchased on Ebay a NEW Microsoft SideWinder ForceFeedback2 Joystick with original packaging (incl. 2 CD-Roms with drivers!). I would like to upload those two CD-Roms (ISO-Files) for the vogons-library.
http://imageshack.com/a/img922/89/aDGgRW.jpg
*** UPDATE: ***
Link for Download: https://drive.google.com/open?id=0B3X30i7OCuH … aUdUV3NJaUlsbWc
so long
Drill_Sergeant_CH
Reply 566 of 1658, by Drill_Sergeant_CH
#push
Reply 567 of 1658, by Stiletto
Drill_Sergeant_CH wrote:
#push
Send SquallStrife a PM, he'd the only person who can give you access.
do the Fandango!" - Queen
Stiletto
Reply 568 of 1658, by Anapan
I just received a Makopad PC (SV-234) in the mail - it's even better than I'd read about - Here's the 95/98 driver and an image:
http://anapan.525lines.moe/sv234.exe
I had to get the driver from Archive.org - I found a directory listing where most Interact accessories' drivers can be downloaded:
https://web.archive.org/web/*/http://www.inte … com:80/dlfiles/*
The driver reports it as Interact PC PowerPad Pro 6-button, tho the driver seems to be different from the one already archived (it is the same driver by file-size that came on the disk which had bit-rotted).
Reply 569 of 1658, by appiah4
I've come to be in posession of an AWE64 Value Installation CD. I know the Gold CD is on Vogonsdrivers (and actually works with the Value card) but if anyone would want me to upload it somewhere let me know.
EDIT: You can download it here: https://drive.google.com/open?id=1qYExwo_A-25 … TSxpZQMXXPWyzJY
And I wish Squallfire would give me an account 🙁 He doesn't read his messages on Vogons it seems..
Reply 570 of 1658, by Solarstrike
New guy here, but page seems to be down.
Reply 571 of 1658, by Cga.8086
yea dns problem, hopefully vogondrivers will be back
Reply 572 of 1658, by SquallStrife
Yep, an update broke nginx. All good now! 😀
Reply 573 of 1658, by firage
The final DOS software releases for a classic Thrustmaster joystick lineup.
The attachment F22_209.zip is no longer available
The attachment FLCS_518.zip is no longer available
The attachment TQS_518.zip is no longer available
The attachment WCS2_813.zip is no longer available
My big-red-switch 486
Reply 575 of 1658, by Drill_Sergeant_CH
updated my Download-Link (see a few posts above) for MS Sidewinder FF2 Joystick Driver CD's. So please add them to the vogons library.
Cheers
Reply 576 of 1658, by blurks
I uploaded the driver files for the VideoLogic DVD-Player (MPEG2 decoder card for PCI bus).
This includes the drivers, the setup and the readme files from the attached disc but DOES NOT include the DVD Player application as I am not aware of its current copyright status.
http://www60.zippyshare.com/v/6I4wWmrM/file.html
Reply 577 of 1658, by Murugan
Is the library down?
Reply 579 of 1658, by Stiletto
Stiletto wrote:
Seems that way.
http://downforeveryoneorjustme.com/vogonsdrivers.com
Back up, BTW.
Stiletto
