Reply 20420 of 58875, by meljor
wrote:Just bought this box for 10€ at Ebay...you see the reason. Hope it still works 😀
Nice find. Since it is in a box with other cards and can be damaged easily make sure to check all the tiny legs of the three 3dfx chips first before testing the card. Shorting on any of these pins will cause the card not to function or function properly. They bend very easily.
Before powering the card it is an easy fix with a needle point and a good set of eyes (or magnifier). Not checking this first can destroy the card.
