Samir wrote:MichaelWeaser wrote:Samir wrote:I somehow think I have this in a bunch of stuff I haven't touched in decades. 🙁 Hopefully someone else has these more accessible for you.
a few days ago I found a web archive of the ESS website, it only has the drivers for the card for windows 9x , and windows NT based, up to windows xp , But I think there was a driver that a company made that made this same ESS modem work for DOS and windows 3.1x>. Another thing is this modem is a ISA plug n play, so the modem is on the ISA bus on my laptop.
I would download the win9x drivers and see if you can find them there. A lot of manufacturers started not mentioning all the drivers in their packages since older stuff was obsolete. Perfect case in point is Intel PCI NICs--you can still find DOS drivers for them in recent driver packages. 😎
Yeah its not there, there are no DOS drivers for it there either. yeah its unknown if the ESS modem even works under DOS , its a total mystery. But I was googling and found what chips ESS used in their modems has been used. http://web.archive.org/web/20080915075215/htt … rivers-dis.shtm this is the archive of ESS drivers on there website , and it even tells what modem Chip(s) is used in a certain ESS modem. The chips were designed by ESS, and used in other modems that weren't ESS, and some of them have DOS drivers even if ESS doesn't supply drivers. most of the drivers for other modems using ESS modem chips use the same drivers as ESS own modem series, for windows 9x . A lot of them did have DOS drivers , So if it uses the same ESS drivers as windows 9x , I am thinking if I can find a DOS driver from another modem that has the same ESS chips as my ESS branded modem , the drivers might work for my ESS branded modem for DOS.
