Reply 7800 of 27521, by liqmat
- l33t
She's looking sexy. Not the lady on the screen. Eyes on the computer. ITT Xtra XP restore is done. This 1985 system was really in pristine condition. The innards look basically unused. Did a vinegar treatment on the underside of the motherboard to clean up residual flux which cleaned up very nicely. Replaced the original full length CGA card with a Paradise VGA. Also installed a multi I/O card for the NIB vintage joystick I have on the way. Reseated every chip on the motherboard as well. The keyboard had a full scrub down inside and out as some of you know from a previous post, but I decided against a retrobrite. All checks out ok. Never did find the driver for that ITT Xtra memory board expansion card so I removed it. It has 640K on-board and that is plenty for a dual 360K floppy system TBH. More than likely the 1MB expansion could not have been used for DOS anyways as my research has led me to articles that explains the memory expansion card was used for hard disk cache, print spooling or a RAM disk via special ITT utilities. Anyways, that vintage joystick I have on the way... I like the whole weird cowboy with the finger guns and the name... WOTTA SHOOTAH...
