First post, by daliik
Hi guys,
i recently bought 486 board for retro gaming. It's an Asus PVI-486SP3, intel DX4 100Mhz, 16MB RAM. I flashed bios to version 0306 so now it detects seagate 4,3 GB drive. However after i installed dos 6.22 and win95 osr2 and all drivers i am dealing with sound problems in DOS and in windows as well. I tried 2 soundcards SB16 nonPNP and then AWE64 PNP but result is the same for both. When i boot into DOS, sound card drivers are loaded as usual. Once i start quake it hangs for while during sound initialization, then it will actually load demo and continue. But, after 3-5 seconds whole demo freeze, hangs there for another 3-5 seconds, then play normally and then again freeze, etc ... after several freezes demo is stopped with some error.
In windows situation is even worse, when i run glquake via voodoo1, it hangs while sound initialization. In control panel, everything is ok, i can even hear windows welcome sound.
When i do all this with "-nosound" everything is 100% stable without freezes. glquake timedemo is 13fps so no performance issues i think as this is normal value for 486 CPU 😀
What i tried is to change bios settings, swaped soundcards, swaped matrox millenium for S3, removed network card, nothing helped. I am starting to be hopeless, don't want to play games without sound especially when i have dreamblaster X2 in my SB16 nonPNP installed.
Any ideas what can i try next?
