First post, by Cadderlik
I have a problem with my floppy 1.44 3.5 in - spec 486 DX2 66 and 16 mb ram. When DOS start from hdd i can use command a: and I see files on the diskette but if I try to copy file or for example start setup.exe I have info "sector not found reading drive A" I've checked other floppies and every time is the same. Floppies work perfectly in other computer with dos 6.22.
I also changed drive to another, changed cable and ram ...no changes. I also used bios default but IT didn't help.
Any ideas ?
When I boot disc 1 dos 6.22 the drive works normal and can run setup.
