Re: What retro activity did you get up to today?
Postby appiah4 » 2018-3-12 @ 07:04
I had two Radeon 7000 PCI cards lying about and had no idea about their clockspeeds, so I plugged them into my P3 system and dumped their BIOSes. In case anyone needs future reference of these:
Sapphire Radeon 7000 PCI 32MB 150Mhz/150MHz Core/RAM
HIS (Hightech) Excalibure Radeon 7000 PCI 64MB 143MHz/143MHz Core/RAM[/b]
The BIOSes for these cards are nowhere on the internet as far as I can tell so I can attach them here if anyone needs them.
Strangely enough, one of the cards has 5ns RAM and the other has 4ns RAM, both of which should actually be enough for the 166MHz regular speed of the Radeon 7000 PCI card. Maybe I should try flashing a 166MHz BIOS onto one of these?
1989:A500R6|512K+RTC|ACA500+|HxC/df1|C1084S
1992:HIPPO-VL+|DX2-66|8M|CL-GD5428|CT2290
1995:PCI597-1|P133|32M|Trio64|V1/4M|ES1868/DreamS2
1998:S1573S|K6-2/400|64M|M220|SLI:V2/12M|CT4500/32M
2000:GA-BX2000|PIII-700E|512M|GF2GTS|MX300
User avatar
appiah4
Postby eisapc » 2018-3-12 @ 08:33
luckybob wrote:oh that's nice. If you need some pointers on dualies, let me know.
I allredy have some experience with dualies, quadies, sixies and an octo as you might noticed from my collection list in the introducing thread on milliways.
The only dual CPU system that is keeping me troubled is my Proliant 1600.
Upgrading a dual P2/333 from Klamath to Dechutes to increase the cacheble memory size and therefor the amount of installed memory without cache penalty, continues to get me configuration errors.
I don´t believe this is due to the hardware, but more related to this weird Compaq EISA configuration tool.
It works fine in a Proliant 3000 using exact the same CPU boards.
As for the heatsinks: Yes, these are heavy beasts designed to dissipate the 100+ W of these Netburst XEONs, but the ones IBM used in the Intellistation M pro seems eaven more solid to me.
The fans are rare for the reason lot of OEM systems like my Proliants and Intellistations use the chassis fans to vent the CPUs using air ducts.
User avatar
eisapc
Postby amadeus777999 » 2018-3-12 @ 11:56
Compared the picture quality of the iiyama 510Pro to that of the SUN GDM-5510 and in DOS/low res latter is a LOT better. The iiyama lacks green in anything low res/60 hz but does look great in windows. It's a truly solid piece of equipment when compared to normal crts albeit it quickly fades when compared to the GDM. I'm happy to have both but it is quite a hassle moving them around at 80+ pounds, especially when one recovers from back problems.
Honorable mention - an old Belinea 19" I got from a friend some time ago which stacks up nicely in the picture department. Not that "high end" but really good and really capable at 320x200(640x400).
Nonetheless in the end totally worth it.
User avatar
amadeus777999
Postby Woolie Wool » 2018-3-13 @ 01:44
[Moved this from another thread that I posted in by mistake]
So, I've posted about my sound issued with my KT7A Athlon Thunderbird rig before. This thing hadn't, until now, worked properly as I poured well over $100 into trying to fix it. It was some ridiculously trivial oversight, but it brought my beige beast to its knees.
I was kind of expecting trouble building this rig. I was vaguely aware of the "VIA haters club", especially concerning the KT133 chipset. I didn't know about chipsets at all when I was 13, but my computer back then was a 1.6 GHz Athlon XP that ran Windows 98 (I wanted my DOS games, but I was only vaguely aware of dual booting and bought into anti-Windows XP FUD), and it was a monumental piece of shit that bluescreened daily and had to be reformatted once a year (I was a pretty terrible user back then, I admit, but it was unstable even when freshly installed). My sister's rig had similar problems and I examined a picture of her motherboard from the time (I sent it to the recyclers because she wouldn't want it and it's a sub-consumer-grade micro-ATX POS with a post-it note saying "board questionable") and it was a KT133, and mine probably was too. Also, Athlons had a tendency to run hot and had what seemed at the time to have a ravenous appetite for power. I think part of its gamer cred back then that it was better for games than the P4 for a while, but it was a loud, hot hassle with a big heat sink that normal people didn't want to deal with--it was a "gamer's processor" in both the good and bad ways. But the thing never, ever worked right. It was usually the sound card, especially when I used an external MIDI module. The sound would never work correctly, no matter how I configured things.
I discovered today that my month-plus of infuriating sound card issues were caused by one little MIDI connector. My MPU-401 breakout cable ends in not one but two MIDI plugs, one for input, and one for output. Not realizing quite how stupid DOS was at the time, I plugged them both into my Roland SC-55, because what could possibly go wrong? Everything. The bidirectional connection with the MPU-401, in DOS and DOS alone (Windows XP never, ever had problems, and I didn't even need to install drivers for any of my cards) almost always caused incredibly bizarre inconsistent, and unpredictable errors, if not outright hanging the system. I went through two Yamaha OPL3-SAx cards (which failed in different ways), ran them in parallel with a PCI SoundBlaster Live!, and now I have the AWE64. The AWE64 seemed to solve the problem, for a while, but after a few hours spent playing games with CD soundtracks, I fired up Doom and it was back, but now it just made DOS games hang on a black screen every time (and UT2004 crashed, but not in any way that hurt the system, once while I was testing it so in my state of rapidly escalating paranoia I was afraid XP was affected. I was absolutely devastated, and I was about ready to sell the motherboard and rebuild the computer as a Slot 1 machine . But while I was taking a shit this afternoon, it occurred to me, it occurred to me that perhaps the fact that the Roland SC-55 can talk back to the computer might cause problems in DOS, so I decided to disconnect the SC-55's midi out from the computer and...
It worked. All the bugs were gone. No, a fast computer does not make ISA cards useless. I was running at 1100 MHz and the music and sound were flawless. I have no idea why the computer is mesmerized into paralysis by the line to the Sound Canvas midi-out. One of the strangest bugs I've ever seen in my life. I blame VIA.
User avatar
Woolie Wool
Postby creepingnet » 2018-3-13 @ 05:21
Replaced my yellowed old CD-RW drive in the 486 tonight with a shiny new-old-stock I/O Magic 16X DVD-ROM, let's just say, you never realize what a bottleneck optical and hard disk media is to a 486 with VESA local bus and a fast VLB card until you put a PIO-3 HDD and a DVD 16x RW drive in one.....The entire Doom Collection installed in 2 minutes, IIRC it took longer last time on my XP machine. For some odd reason it seems to have boosted the Windows 95 boot time even moreso (as if it was not short enough already)....takes about 15 seconds to boot from the minute it hits the DDO.
New DVD Drive in place
For gigggles tried out WinDVD, it stops responding in Win95, LOL. Not like I expected much else. This was more of a cosmetic (and apparently performance) upgrade than anything else.
Maybe I should play with some Linux Live CD's, LOL. Seems like the more I push this thing, the more I find out it can do. Seems to go pretty willingly into post-486 era territory with a gusto I've not seen since the IBM PC-330 100DX4 I had years ago, and it seems at this point it's doing all that BETTER than the PC-330 did. Go figure.
My DOS Boxen
85' Tandy 1000(a)- 8088/4.77, 640K, 8gb XT-IDE, TGA, 3-voice
89' GEM 286 - 286/12 w/287, 6MB, 1GB SCSI, 2XCD-ROM, ET-4000 1MB, SB Pro2
Creeping Net 486 - 486DX4100 WB, 128MB, 512K L2, 15GB+40GB, S3 809 2MB VLB SVGA, SBAWE64
User avatar
creepingnet
Postby CkRtech » 2018-3-13 @ 07:28
Wow. Dig that setup, creepingnet.
User avatar
CkRtech
Postby derSammler » 2018-3-13 @ 09:57
Modded my SC-88 Pro to get rid of the fixed power cable.
derSammler
Postby stege » 2018-3-13 @ 13:20
Starting with today, I'm drinking my coffee from this left-in-a-drawer-to-die.
Miss the monkey island days, the space quest days, even the longest journey days.
stege
Postby appiah4 » 2018-3-13 @ 13:22
Secured the donation of a Radeon X1950PRO AGP so now I have all the high end ATI AGP cards to test with my Socket 754.
Sometime. In the future.
*sad*
User avatar
appiah4
Postby TheAbandonwareGuy » 2018-3-13 @ 13:31
Boycotting CPUWorld because they now force you to disable adblock to see detailed information.
Nope, I don't care you rely on ads. I'll get my information somewhere else.
Anyone else want to join me in the boycott?
https://www.youtube.com/channel/UCuFY6Z ... 2tV8b00x_A
1996|P200MMX|64MB EDO|Virge DX 4MB|SB16 OPL3
1999|P3 933|384MB SDR|GF2 Ultra 64MB|CT4620
User avatar
TheAbandonwareGuy
Postby Cyrix200+ » 2018-3-13 @ 14:09
TheAbandonwareGuy wrote:Boycotting CPUWorld because they now force you to disable adblock to see detailed information.
I feel that CPUWorld is a useful resource, I use it a lot. I don't like ads, especially if they are intrusive and/or a part of a data mining network (which they pretty much all are). I DO care that they need some sort of income. How else are they going to rationalize working on that site? There are bills to be paid every month, and it also takes time.
It would be great if they had some sort of donation/membership system.
I have personally decided to disable my ad-blocker on their site. (but I must admit, only after they started blocking information after a few requests/day last year, which they later stopped doing again).
EDIT: a boycott is a good way to protest their way of working though, if you disagree. But what do you expect them to do? And if you can get your information elsewhere, there isn't really a problem for you is there?
Retro workhorse: Asus P2B-LS | Tualatin Celeron 1400MHz | Matrox G400
Image gallery
User avatar
Cyrix200+
Postby appiah4 » 2018-3-13 @ 14:14
Eh, I have them on adblock exception list happily.
User avatar
appiah4
Postby Eleanor1967 » 2018-3-13 @ 14:25
No, they are usefull to me and if thats their way of generating income I'm okay with that. (Atleast if I do not get a virus through the ads, which happens to the best. Thats the only problem I have with non intrusive ads)
Eleanor1967
Postby Shagittarius » 2018-3-13 @ 14:37
I stop going to ANY site that wants me to disable my Adblock. There are too many resources to bother.
User avatar
Shagittarius
Postby oeuvre » 2018-3-13 @ 16:31
To view this post, please disable your adblocker.
IBM Aptiva 2176-C73 Pentium 200, 64MB, Matrox Millennium II, IBM HD, AWE64, DOS/95
HP EliteBook 840 G3 i5 6300U, 8GB, Intel HD520, 256GB M.2 SSD + HD, Windows 7
i7 6700K, 32GB, EVGA GTX970, 256GB M.2 SSD + HD, Windows 10
User avatar
oeuvre
Postby bjwil1991 » 2018-3-13 @ 16:59
Looking online for A/V cables for my C64 as the one I made is a little fidgety at times (if I tap the cable, there'll be jailbars or loss of color as I didn't solder all the way for the resistor), and there is a website that sells that particular A/V cable that has composite, s-video, and "stereo" audio for a reasonable price.
To view this post, please pay an additional $10/mo and disable your ad-blocker.
C64, WheelWriter 10 Series II QuietWriter 8, Pack-Mate 28 Plus, K6-2/300, Pavilion N3350, iMac G3 & G4, Socket 370, 2x Inspiron 600m, Athlon 64, Dimension 4550 & E510, ThinkPad R40, Presario C700, ASUS X54C, Raspberry Pi B+, 2B-3B+, Custom FX-6300
User avatar
bjwil1991
Postby eisapc » 2018-3-13 @ 19:18
Had a close look at the Tyan board mentioned above and replaced the memory and the CR2032. It proved one of the DIMM memories was bad. Now its booting finally.
User avatar
eisapc
Postby badmojo » 2018-3-13 @ 19:45
TheAbandonwareGuy wrote:Anyone else want to join me in the boycott?
What do you propose they do to fund their very useful activities? Everybody wants something for nothing.
If it's broke, then fix it!
User avatar
badmojo
Postby luckybob » 2018-3-13 @ 19:59
Because so many ads take up massive amounts of bandwidth, take over your screen, give your system herpes, start some video with sound that you don't want to hear, etc. People found a simple way to get rid of everything. So the more legit places suffer too.
User avatar
luckybob
Postby bjwil1991 » 2018-3-13 @ 20:12
I use ad blocker because ads take too much memory on my computer and filling my hard drive with spyware/adware.
User avatar
bjwil1991
PreviousNext
Who is online
Users browsing this forum: britain4, F2bnp, mpe and 12 guests
