Terrible performance help, 486SX-33
First post, by narunetto
Hey everyone, I recently got a Packard Bell I've been trying to restore and I finally got everything software wise where it needed to be but after booting it up for the first time everything was painfully slow. It took 5 minutes to even get the Windows 3.11 install to boot to idle and everything is laggy including the mouse! I downloaded Norton System Information 8.0 and ran the CPU speed test and well... it doesn't seem right at all. I've attached the benchmark result, which is 3.8.
I'm lost on where to go here... is the CPU dead? Is something screwy in the configuration? Any help would be very greatly appreciated, thanks!
    327.64 KiB
Reply 1 of 21, by Jo22
Well, I'm not sure at the moment. Maybe some sort of throttling function is enabled (any turbo button pins on the mainboard ?)
Did you try to reset the CMOS (BIOS) settings to defaults ?
Reply 2 of 21, by narunetto
Yeah, the defaults have been reset a few times. From what I can tell with various diagrams, there's no turbo button but there's a software turbo function, but if I try to use it it beeps as if it's been turned up all the way even after pressing it multiple times. I thought that at first, honestly but nothing really changed.
I attached the BIOS config but there's not really anything there I can see.
    425.27 KiB
    426.93 KiB
Reply 3 of 21, by derSammler
Turbo button not pressed...?
is the CPU dead?
No, that's not how computers work. The speed will not magically decrease. The CPU can either maintain its speed or not. In the later case, the system would simply no longer work at all.
Reply 4 of 21, by narunetto
I pretty much thought that was impossible but from all of my years with this stuff, this one is puzzling me. There is no physical turbo button on this system and no place I can see on the motherboard after looking at 3 diagrams of it.
Reply 5 of 21, by Azarien
Can you tell us what mainboard is that exactly?
Reply 6 of 21, by F2bnp
Since this is an OEM build, it's probably an OEM board. Could you take a few pictures of the board and available jumpers and perhaps give us a link to the manual? This does seem like a turbo or cache issue, perhaps you're missing something.
Reply 7 of 21, by BinaryDemon
Could this be one of those situations where you added more memory than the motherboard supports? 20mb isn’t a very typical 486sx-33 oem configuration. I’d try with 8mb.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 8 of 21, by Jo22
Is the CPU fan working properly ? Some systems throttle if there's no fan detected.
Reply 10 of 21, by narunetto
http://j12345.users1.50megs.com/menu/pb430/pb430lay.asp.htm
This is the motherboard, it doesn't have any extra cache in the sockets which seems to be normal after looking up videos and stuff about similar ones. I can get some actual pictures later if needed.
I actually put more RAM in it after I figured out this problem just for a troubleshooting step, didn't change anything.
Reply 12 of 21, by narunetto
The problem with that is, its a full front panel connector that is one long connection. Maybe it's failed I guess? I didn't think about that. There's no actual buttons from that connector unless they're hidden under the front plastic.
Reply 17 of 21, by narunetto
I got another screenshot from another utility. Says it's running at 15 MHz... cool... it really does seem like a turbo problem but nothing really changes when screwing with turbo options.
    130.54 KiB
