Reply 8560 of 31264, by PTherapist
Made some modifications to my IBM 5160 XT build in an ATX tower case. Swapped the original case power button, for a spare AT-style on/off switch.
Soldered and glued the power cables from the ATX to AT adapter onto the connectors and then attached the new switch to the case.
Some of these ATX to AT adapters have stupidly small cabling, it was a tight fit hence the use of the glue to keep the cables in place and not stress the solder when screwing the power switch in place.
I still need to create a proper backplace, just using a piece of card for the time being. It may look ugly, but it's doing the job.
Reassembled for now, the next stage is to clean this case up properly.
Now if only I could do something with the case's Power LED & Reset Switch it'd be almost perfect. But oh well. 🤣
