I am out of ideas with this board
First post, by Murugan
Recently I bought a nice lot of retro HW, including semi or finished systems.
This weekend I wanted to tackle one particular system because I had this case when I was young and I always wanted it back.
When I opened it, there was no CPU in the socket. After checking the motherboardtype, I installed a P75 because mine came with a P75 too.
Double checked before turning it on aaaaaannnnndddd.....nothing.
Next step: disassemble the PC, look up some info on jumper settings etc and still nothing.
I can feel the CPU heat up but I get no image.
When I removed the ODIN RTC chip, I was a bit brute and 2-3 legs are snapped off so I can't install that back.
What I have tried so far:
* installed P75 and P100 CPU and set jumpers accordingly
* used single and double sidded SIMMS and set jumpers accordingly
* tried 3 PCI and 2 ISA GPU's
* removed all the cache chips (I thought they were not correct for that board but need some help with that too)
It's a Chaintech 586SLB-P102
http://www.elhvb.com/mobokive/Archive/Chainte … 5xxxx/5slb0.gif
I hope it's not FUBAR 😀
Reply 1 of 28, by Skyscraper
The board will not POST without RTC. The RTC module is more than a button cell battery in black resin.
Reply 2 of 28, by Murugan
Hmmmm that thought crossed my mind but I was not sure if the RTC would prevent posting. I always thought it was only a battery but then again I'm quite noobish when it comes to retro.
I also removed the VCC jumpers since I don't find any info about it on that 'manual' I linked.
I think I mistook them for other jumpersettings so I hope I didn't fry something.
There is not much to be found about this board it seems.
Are the cache chips correct too?
So the only choice is to order an Odin RTC and hope it's not money thrown away 😀?
Reply 3 of 28, by derSammler
Exactly. No RTC means no CMOS. And it won't POST when no CMOS is present at all.
Reply 4 of 28, by Murugan
Stupid me....pfffff
Well I ordered 2 on Aliexpress.
Takes a month normally...
Will come back later on.
Are the cache chips ok?
Reply 5 of 28, by luckybob
Those cache chips seem.... off. They don't look quite right. You might need to disable the L2 cache to get it to post.
Reply 6 of 28, by Murugan
Will need to Google a bit then. I'm slowly learning.
This is how I Found the board. The chips are also smaller than the sockets. Weird no?
Is there a Page with more info on this board except for that bad scan 😀?
Seems like for some periods and or companies,info was lost or not decent documented.
Ik hope I didn't screw up with jumpering that vcc...
Reply 7 of 28, by luckybob
Murugan wrote:
Will need to Google a bit then. I'm slowly learning. This is how I Found the board. The chips are also smaller than the sockets. […]
Seems like for some periode and or companion,info was lost of decent documented.
no, its normal. The longer sockets are for 512k and 1024k chips.
Reply 8 of 28, by Murugan
Thanks for the help and info so far.
This board can take max 1024k or so,so am I mistaken or are there even too much of these chips installed?
Reply 9 of 28, by luckybob
no, long story short, the chips are 256 K bits. So eight of them equal 256 K BYTES. Looking at your board, at the middle left, there is an empty space for a chip. left of the ISSI chip. These 2 chips are your TAG ram. You only have one 28-pin chip. So you are PRACTICALLY limited to 256k L2 (and 64mb of ram). If you populated the left chip with another 256Kb chip like teh ISSI one, then you can upgrade the cache past 256k.
Again, I'm glossing over MANY details. I'm sure you can google the details.
Reply 10 of 28, by Murugan
Will Google some more then.
It will take some time before I het the chips so I can study some more 😀
Thanks!
Reply 11 of 28, by lazibayer
I just checked the datasheet of SiS 85C501,
One 32K x 8bit tag ram is enough for 1M byte cache. The solder points on the left of the ISSI chip might be reserved for a 2M byte variant, or the dirty bit chip.
Reply 12 of 28, by luckybob
If you read the text at the bottom, without the dirty bit you are limited to HALF what the table says. So you only get 32mb with 256k. There are only 8 chip sockets so anything ending in x16 is not an option for this board.
So if you wanted 1mb L2 you need to fill that empty spot with a 32Kx1 chip.
Reply 13 of 28, by lazibayer
Without the dirty chip the board can still work with 1M byte cache. The cacheable RAM is down to 64MB, which is still more than enough for any period correct application the board can handle.
Reply 14 of 28, by Murugan
Finally the ODIN RTC has arrived. Inserted it in the socket and yuy it works.
But now I'm trying to finish the build but I have no clue at all where to connect the HD and Turbo led. There are some open spots where reset,keylock etc are but I don't know what they do.
The link that I posted with the GIF shows nothing about these 2. I don't seem to find a more elaborate manual for this board.
Is there even a manual for this thing?
Reply 16 of 28, by Murugan
Hmmmmm indeed it does! So weird that the jumper setting quick reference doesn't mention these 2 jumpers at all. If you look at the schematic I linked and the first picture, the amount of jumpers isn't even the same!
I just found the 5SLM (in another thread here mentioned together with the 5slb) and J23 might be one of the missing 2. I just don't want to fry this board 🤣. On both the 5slm and 586SLM.3, J23 is for the turbo led so I can pretty much accept that J23 will be the same here? J21 is on both boards for CPU speed selection but on the SLB it's JP10-11. And there is a JP21 too so will need to figure out what that is for.
Another look at the board tonight is on the menu and I'll take a pic to be sure.
Reply 17 of 28, by PCBONEZ
I think this one is actually 'it'.
Seems Chaintech sometimes drops the "86" thus 586SLB becomes 5SLB
http://stason.org/TULARC/pc/motherboards/C/CH … ium-5SLB-1.html
Reply 18 of 28, by Murugan
It's indeed that board but there are jumpers on this board that are not on the picture nor mentioned anywhere. There is no information where to plug HD and turbo led.
Reply 19 of 28, by lazibayer
The HD LED connector is located at the right bottom of the last picture of the first post.
