First post, by jamesbeat
I'm having a weird problem with a compact flash card.
I have one of those generic IDE adapters, and I got it working fine in my Dell Dimension 4100.
I unplugged the hard drive, plugged in the adapter/card combo, partitioned it with fdisk, formatted it, and copied the contents of the boot floppy to it.
I also copied Prince of Persia over for, you know, scientific testing purposes 😀
I ejected the floppy and rebooted, and everything went fine.
I played a couple of levels of Prince of Persia, then shut the machine down and removed the card.
I then set up my new Asus CUSI-FX motherboard that I bought for my Via C3 build, and it won't boot from the card.
It is recognized as a 32MB hard drive, but when it tries to boot from it, it gives a disk I/O error.
I can't understand why it would work in one machine but not another.
Any ideas?
Reply 1 of 9, by jamesbeat
Just bumping this - still having no luck.
The compact flash boots fine in two other machines, but gives an I/O error in the machine I actually want to use it on.
The same machine boots fine from a regular hard drive.
I have tried the CF card on both the primary and secondary IDE channel with the same result.
I know some CF cards don't play nice as hard drives, but in this case I know that this particular card works fine in at least two machines.
Are there any characteristics of CF cards that might make one compatible with only certain machines?
Reply 2 of 9, by Jo22
I'm sorry, there's not enough information to help you.
The problem could be anything.. 🙁
What kind of mainboard is it ? The page I found has little information about it.
Also what kind of CF card is it (brand, type I/II, 3.v3v/5v, etc) ?
Best regards,
Jo22
Edit: http://en.wikipedia.org/wiki/CompactFlash#CF+ … ation_revisions
Reply 3 of 9, by jamesbeat
Here's the motherboard manual:
https://www.google.com/url?sa=t&source=web&rc … oPeLIZpCHuleBXE
The CF card is an RCA branded one, which means it could have been manufactured by pretty much anyone I guess.
I got it with a digital camera I bought on eBay about ten years ago.
It's 32MB and I don't know the voltage - I just left my adapter set at the default, which is 5v and it works fine in the two other machines I tried it on, so I left it like that.
The other jumper is for master/slave, which I left set to master.
Reply 4 of 9, by tabm0de
This might be stupid, i hade the same problem on one of my machines, but it seemd to be becouse of the cpu. i changed to another cpu and i worked fine, unsure if i have done wrong cpu config.
naa, nothing yet...
Reply 5 of 9, by konc
Start over with fdisk /mbr, partitioning and formatting the CF on the machine you actually want to use it.
Reply 6 of 9, by .legaCy
One question: the cf parameters that the bios detect is the same across the working and non working machines?
Reply 7 of 9, by Qjimbo
Random theory: Could be the PSU, I know that memory cards/compact flash are really sensitive to incorrect voltages.
Follow me on twitter
Reply 8 of 9, by r.cade
I always run into issues where the geometry is not detected the same across machines when I try to swap them. Agree- wipe the CF (completely) and fdisk/format/sys on the actual machine you are working with.
Occasionally they are stubborn and this won't produce working system either with some CF cards.
Reply 9 of 9, by jamesbeat
Thanks for the tips everyone - I'll try reformatting on the actual machine and report back.
If this works, I hope the card still works in the other machines.
I'm hoping to use this card as a way to transfer files from other machines.
