Reply 8680 of 31262, by dionb
- l33t++
My elder son is away with his grandparents so I actually had some time to do something again this evening.
- built the IBM PS/1 LPX motherboard (So1 LIF with IBM Blue Lightning DX2 - sadly not the DLC version, but nice nonetheless) I received in the post today into a generic LPX case.
- installed DOS 6.22 on a 512MB CF card
- discovered that LPX != LPX when it comes to risers and expansion cards. With the riser belonging to the board, cards are about 5mm too far 'in' the case to fit. Had to remove the back plate to get it in the slot. Time to find a riser that does fit the case and hope it fits the motherboard...
- messed around with my Aztech Waverider32+ again - still failed to get the "wave" bit working.
- fortunately I recently got my hands on an MT-32, so hooked that up for MIDI instead. It does work 😀
