Reply 8720 of 27689, by NamelessPlayer
- Member
With Socket 370, you definitely have to watch out for FC-PGA and FC-PGA2 compatibility. I definitely wish I'd done more research before picking up that Abit BP6 years back, not knowing that board needs extensive modification to support FC-PGA Coppermine CPUs, especially in dual CPU mode as intended.
Meanwhile, more adventures with the Power Mac 9600:
-Going non-interleaved on RAM really helps with stability, that's for sure. FireWire transfers just work, the Finder hasn't crashed without input even once...
-Unreal Tournament is a real wake-up call, though. It's a slideshow on the 9600 with its Rage 128, moreso than I remember on my iMac G3 350, which wasn't all that great at running it, either. On top of that, 192 MB of RAM is not enough to actually get into a match without being slapped with an "out of memory" error. I guess this one's best reserved for late G4s that you can slap a fast AGP Radeon into - or you could just take the sensible route and use pretty much any PC from the last decade.
-I shudder to think of how much file system corruption I would've had by now in all the time I've been tinkering with this thing, had I not had Norton Utilities on hand. Seems like the worst of it happens if the system just seizes up during a FireWire transfer.
At the very least, I'm gonna cram more RAM in there, maybe a Radeon of some kind. I suppose it wouldn't hurt to borrow the 9250 PCI that I slapped into my MDD temporarily, and see how badly the 9600's dated architecture with the 50 MHz bus and EDO DRAM that I can't even run interleaved bottlenecks the whole thing...
