A tale of two PSUs
Reply 401 of 472, by gdjacobs
ODwilly wrote:
Here is a dumpster find I found. Still works! Had a rather nice made molex to P4 connector attached to it and after replacing a couple bulging Fuhgyuu's it seems to work fine.
Anyone tell from my cellphone pics if it is decent enough for a spare for a low-end Slot 1 rig?
Here's a summary of what I can see:
Input filtering looks complete. The daughterboard on the plug should result in an easy pass for EMI.
Component selection appears to be good aside from capacitor brand. Primary caps, transformers, and heatsinks all appear to be a healthy size. Based on what I see, the power rating for this supply is conservative.
Output pi filters are complete which should result in respectable numbers for ripple.
All good signs so far.
Here's what I can't see:
Transistor and diode selection, so I can't tell if the supply is definitely good for 250W, nor can I tell what is used to generate the standby rail.
Reply 402 of 472, by ODwilly
gdjacobs wrote:
Here's a summary of what I can see: Input filtering looks complete. The daughterboard on the plug should result in an easy pass […]
Thank you, Im going to assume from the rest of the build quality that they cheaped out on caps and didnt cheap out on the transistors and diodes. The amazing thing is how close to spec the rails are, the 12v reads 11.9 and the rest of the rails are either perfect or the same distance off. Now that the 2 Fuhgyuus are gone the Crapxons are next up!
Reply 403 of 472, by Nvm1
I opened up the PSU of the AT Tower I received for two weeks.
1 cap bulging, 2 have blown/vented alot. I am in dire need of some AT PSU's for my rebuilds.
My question, is this AT PSU worth salvaging by replacing the caps or not?
1.82 MiB
AT PSU Internals1
1.84 MiB
AT PSU Internals2
1.67 MiB
AT PSU Internals3
1.74 MiB
AT PSU Internals4
1.65 MiB
AT PSU Internals5
Sorry for the Potato pictures, I hope they still are clear enough to see the important pieces.
Reply 405 of 472, by Ozzuneoj
I'm certainly not an expert on power supplies, but bulging or leaking aluminum electrolytic caps are fairly uncommon on devices made before 1999 or so... I've only seen them on a few very very low end Micronics SS7 AT boards. Anything with visibly defective caps before they were common may have been built with especially cheap components all around. I wouldn't bother with it.
Reply 406 of 472, by DAVE86
It's '90 generic at best. Has some EMI input filtering, though not all components are the safety approved type. Has a bridge rectifier, small input capacitors and the primary transistors are plastic to-220 types. Main transformer looks like EI33 size. Good enough for 200-230W depending on the switching frequency that KA7500 is configured to.
Secondary protections are most likely handled by that other chip which is a dual comparator.
The secondary heatsink is a bit flimsy. That two 3 amp diodes bunched together are the rectifiers for the 12V rail. It might not be an issue if the 12V rail is specified 4-6 amps max. The 5V rectifier looks decent, probably 20-30 amp rated.
If you have the time and spare parts/know-how you can try to revive and even beef the unit up a bit. Othervise don't bother with it.
Reply 407 of 472, by Nvm1
Okay so for a 486 VLB or a Socket 5/7 system with nothing special in it it can be used.
Changing caps should be easy, recapped alot of newer units where space is really cramped.
Other things I can improve outside replacing the old Fan and the old caps?
Reply 408 of 472, by TheMobRules
You could improve the input filter by scavenging safety approved X and Y caps from other units and if you manage to fit larger heatsinks it may help with heat as those look quite thin. Other than that, it should have no problem powering a 386/486/Pentium machine.
Reply 409 of 472, by gdjacobs
The filter network isn't really even sufficient, so I'd probably retrofit it with an additional self contained filter can.
Aside from that, it's minimally sufficient at best. I'd like to echo everything DAVE86 said (he's much better at spotting transformer sizes than me), plus the secondary filter isn't very robust, and protection is probably quite rudimentary, maybe OVP only. I would really only bother if you haven't got any other AT supplies and you're absolutely dead set against using ATX to AT adapters.
Reply 410 of 472, by okenido
Hi folks
Found this PSU, its working and quite clean, i was wondering if it's worth keeping and recapping ? Would be for some PIII setup.
1.76 MiB
1.64 MiB
1.78 MiB
1.58 MiB
Reply 412 of 472, by Ozzuneoj
If it's working, passes basic PSU tests and doesn't having swollen or leaking caps, I wouldn't bother recapping it. You're more likely to introduce problems to a working unit unless you recap boards all the time and are very experienced. It'd also depend on the brand of caps. If they're a decent name brand, they may last years without causing any problems.
Reply 413 of 472, by okenido
There seems to be two brands of caps, one labelled "DON" and one with some 'Y' logo in a circle.
I can solder easliy on the simple PSU pcb's, I was thinking about recapping since i've had some issues recently with old hardware - Randomly failed IDE drive detection, motherboards and GPUs that worked before and stopped working for no reason... I was using random PSU from my spare, they all work but some have bulging caps, I'm afraid it will kill my hardware even if caps look OK (their capacity decrease over time)
72.56 KiB
93.11 KiB
Reply 414 of 472, by gdjacobs
You should be able to find a ~250W ATX PSU from an OEM unit that's as or more powerful than this one (in reality) with proper component selection, construction, and circuit protection. This guy is probably a two transistor standby PSU that's ticking away waiting to go *boom* all over your retro parts.
Reply 415 of 472, by okenido
Do you mean the transistors in this PSU may fail prematurely despite the new caps ?
I also have two Delta OEM power supplies (200W but it says the total output can't exceed 110w), they are a bit newer than the FGI since it has a SATA connector
Reply 416 of 472, by gdjacobs
The Delta probably has a 110w limit on the 5V and 3.3V rails combined. This would be fine for a basic P3 without a huge stack of drives or peripherals.
The biggest problem will be if the transistors don't fail. An out of control PSU can potentially deliver huge amounts of energy to your components in the form of voltage in excess of breakdown levels or high current in the event of a short on the motherboard, for instance. One of the most important functions of a power supply is to gracefully shut down in the event of such abnormal operation.
A two transistor standby circuit is ultimately one of the cheapest ways of implementing 5V SB. The problem is that two transistor standby circuits are not robust at all, often featuring little or no protection. Hell, switching control can even be generated via an LC tank circuit, a Zener reference, and a handful of other generic caps and resisters from the Shenzhen market.
Reply 417 of 472, by retardware
Now I have a tale of two AT power supplies also.
According to the date codes, both are manufactured ~1996.
I´ll begin with the Enermax E251BT-V, and continue with the Seasonic SSG-200G after the Enermax issues got fixed.
I got the PSU with an AT case that I bought for my upcoming 486 freeclocker build. It also contained a Pentium mobo which worked fine at my initial tests, so the PSU was proved not to be dead.
To make sure that the PSU is in good shape I decided to clean it and replace the fan.
However, after the work done, I did measure and the PSU shows 10.9V on the 12V line, and 5.32V on the 5V line, which are out of specs.
A crude ripple measurement using multimeters' AC mode showed (approximately) 124mV on 12V and 19mV on 5V.
Sadly it is sunday and I found only some 12V 0.8A fans I could use as temporary load. Will have to get some big load resistors.
In addition I found some strange things on the PSU, which I cannot judge, as my knowledge of electronics is very limited.
So I hope you guys know what is wrong (or what I did wrong) when I show you the photos.
The PSU label
PSU quite dirty outside, grimy smoker homes' dust
The inside after opening looked better than I expected.
No Schaffer filter can, as usual. Will have to order one.
Decided to replace the old fan (right), which stopped quite soon when tipped with finger indicating worn bearing, with a more powerful fan I took from a server (left).
When examining the drive power connectors I found some oil residues, apparently "Kontaktspray" which seems to be popular with some people even in areas where it does not belong.
This obviously did not resolve the underlying cause, low quality, easily worn out connectors. Look how loose they must fit! A true HDD killer plug! Off with that crap!
Replaced these with drive power cables I snipped off from an ancient Fujitsu server. Enterprise quality stuff definitely looks better than consumer grade 😀
Lots of colophonium drip residues on the components side, which remained at factory cleaning. Removed because they have the potential of becoming conductive.
This confuses me a bit. Do diodes work better when well-heated by cramping under that coil?
Another strange view.
D11 and transformer battling for space, with the latter having to retreat a little bit.
D14 as heater to bring C17 to boiling temperature?
Anyway, 12V have 2000uF, 5V has 2200uF, didn't look at values for -5V and -12V.
All outputs, even the negative ones, seem to have pi coils.
Caps rated 105C and have a logo "CTC".
There are two chips, one LM339N and KA7500B (?).
Mounted at the secondary cooler are BYQ28X 100 (I guess some kind of transistor?) and NDS40-30 (dual diode).
The two primary cans have 470uF and are Japanese brand. However, they are rated 85C only.
Rectifier is big block mounted in good height above PCB. Couldn't read full type, obscured by caps.
Switching transistors are NT2625N.
PCB solder side looks acceptable to me, just cleaned dust and colophonium residues.
As I prefer optimal cooling, I connected the replacement fan directly to 12V, not using the fan thermo controller circuit.
(I remember having read somewhere this would be bad - is this true? If so, for which reasons?)
Now my questions:
-What could be the reason for the voltages out of tolerance margin?
Was it only because of wrong minimum load?
Or are the "CTC" caps dried out or otherwise bad and should be replaced proactively?
Or other defects?
I also would appreciate if people who know about power supplies could comment on the technology and quality of that PSU.
In particular important to me is to know how big the risk is that this PSU blows up the retro rig, respective which kinds of protection circuits it has.
Reply 418 of 472, by retardware
Decided to use that Pentium mobo as test dummy.
With it connected, the voltages are fine: 5.12V and 12.10V, with a ripple of 4mV and 30mV, respective. Very good!
So just a fan as dummy load was way too small.
The other questions still remain...
Have used many Seasonic and these seem fairly good.
Not sure what to think of Enermax, as this is the first power supply of them I looked into.
At least I have the feeling this PSU might be a honest 250 watter...
Comments welcome 😀
Reply 419 of 472, by wave
You can't really measure ripple with multi-meter, as the multimeter is too slow to catch and show you any kind of ripple.
Ripple in smps is high frequency (20KHZ and more) and the multimeter would barely be able to show some fluctuations in voltage. Btw trying to measure ripple both with multimeter and also at V AC is 2 times wrong.
