First post, by Aglenoth
Hello ,
Iam building 98’ PC with Super Socket 7 k6-2 500 however my base which is Compaq Presario 7479 has only PCI slots and some integrated ESS allegro 1, I was thinking about SB Live SB0100 since they are quite common in place I live , and I wanted to ask what are your opinions 😀
Any help is hugely appriciated 😀
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Reply 1 of 15, by cyclone3d
For DOS, the SBLive is not going to be very good. It will be good for Windows.
Your onboard ESS sound should work for DOS. You just need to install the drivers/software.
Make sure to have the ESS???.INI file in C:\. Not sure of the exact .INI file name as I haven't set up an Allegro under DOS.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 15, by brostenen
I recommend an YMF-724 card. They are the best for a hybrid Dos/Win98 PCI soundcard.
If you were going for a Win98 only PCI stereo card, then the Vortex2.
If you are going for a surround and Win98-Only card, then the SB-Live.
SB-Live is crappy for Dos, and it has some issues regarding stereo playback.
Reply 3 of 15, by Intel486dx33
Aglenoth wrote:
Hello ,
Yes, Phils computer lab has drivers for Sound Blaster live 5.1 DOS drivers.
He also made a video on how to hookup S/PDIF Toslink to your Sound Blaster live 5.1 in DOS and Win3x.
Hookup the Toslink S/PDIF to an A/V Audio receiver for 5.1 or 7.1 Surround sound. Just let the AV receiver handle the signal processing.
I think this is the best Sound Blaster card for DOS in PCI
The Audigy 2 zs is not supported in DOS.
https://www.philscomputerlab.com/sound-blaster-live.html
https://www.youtube.com/watch?v=rVNSyRAwVXs&t=1s
Reply 4 of 15, by canthearu
I say use the onboard ESS.
The dos compatibility should be very good with it, and it's FM synthesis is pretty good.
The SB-Live is not too bad either, even for DOS games, as long as you can actually get it working on your particular system. But the ESS onboard will have higher compatibility.
Reply 5 of 15, by Aglenoth
But where should I look for drivers ? Or should I just use windows 98 DOS mode ?
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 6 of 15, by elod
Just run the games straight from Windows. It's what was expected when Win98 was designed.
Reply 8 of 15, by Aglenoth
Idealy both
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 9 of 15, by Flare
If you can get it set up properly, and your motherboard supports D-DMA, this Yamaha YMF-744 card sounds great in my DOS machine without a PC-PCI cable:
https://www.ebay.com/itm/282981342279
The manufacturer also has the latest drivers available on their website.
Reply 10 of 15, by Bige4u
Im looking to do the same, to find something better than what im currently using.... i play mostly windows and just a handful pure DOS games, the yamaha sound card suggested by "flare" lQQks like a good canidate because trying to locate a decent vortex2/diamond monster sound mx300 sound cards is getting hard to find, but keep in mind, im not looking for anything fancy, just good, clean, and undistorted sound.
SPECS:
CPU - Intel 1.0Ghz 133fsb Coppermine
MOBO - Intel D815BN s370 mATX
MEM - Crucial 2X256mb pc133 cl2
HARD DRIVE - WD Caviar 20gb pata 7200rpm
VIDEOCARD - Abit Siluro GF3 64mb AGP4x
SOUNDCARD - HP Creative Sound Blaster AudioPCI 128 ES1373 CT5801
POWER SUPPLY - Enermax 420w EG425P-VE
Dell DVDrom - Dell 3.5'' floppy drive
Windows98se
Pentium3 1400s/ Asus Tusl2-c / Kingston 512mb pc133 cl2 / WD 20gb 7200rpm / GeForce3 Ti-500 64mb / Sound Blaster Live! 5.1 SB0100 / 16x dvdrom / 3.5 Floppy / Enermax 420w / Win98se
Reply 11 of 15, by cyclone3d
Bige4u wrote:
Im looking to do the same, to find something better than what im currently using.... i play mostly windows and just a handful pu […]
SPECS:
Windows98se
The Yamaha cards are very nice. Check out Philscomputerlab review on youtube.
And If you want a Vortex2 card, going Diamond is just silly for the price. Look for the Turtle Beach ones (Dell OEM). Just have to make sure you get one withe the Vortex2 chip as Dell didn't change the model number between the older and newer cards.
YMF7x4 Guide
Reply 12 of 15, by appiah4
Go for an AWE64 Gold if you can find one; the 4MB RAM will have you covered for some sweet General MIDI when AWE32 compatibility is not enough, it has great SB16 compatibility and has CQM FM. Overall the nicest card there is for Socket/Super Socket 7 systems in my opinion.
Reply 13 of 15, by Roman555
But from this PhilsComputerLab video I understood that ESS Allegro-1 ES1988S has got horrible FM synthesis 😕
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 14 of 15, by amadeus777999
I have a few SBLive cards(4830, 4670, 4760) and they worked on every system thus far.(486 era boards are problematic though if you want "music" playback)
Reply 15 of 15, by oeuvre
AU8830 MASTER RACE
