First post, by Batyra
some time ago I made a red PCB socket 7 build. With red motherboard etc. a fellow vogoner (@cokebottle) helped me to find red pcb sdram (once again huge thanks to you)...
now I'm making blue pcb slot 1 build with blue PCB gigabyte GA-BX2000+, blue PCB voodoo 3 from incredible technologies (modded arcade) etc...
I managed to buyl loccaly one stick of sdram in original blue cover...
26.2 KiB
I also know that OCZ produced both red pcb ram (like the one I have, it was fire series) and blue (it was ice series or something like that)...
Please help me find something. It need to be blue PCB or original blue cover - no mods, painitg etc. Maybe some of you have one? It can be both similar to the one I got (branded dramex) or other but on blue pcb.
Thanks!
Reply 3 of 11, by Batyra
@Auzner - thanks I ahve seen it before - but I don't like "modding" so I definitely preffer original solution.
@derSammler - thanks a lot... I have seen some ddr's but thats the issue I need DIMM - but please check it! - Thanks
Reply 4 of 11, by Batyra
That is incredible. Always when I cannot find something and ask for help I manage to find it... this time even loccaly 😀 Yaaay!
Thread to close then!
Reply 5 of 11, by Tetrium
Those heatspreaders look very similar to the ones found on contemporary RDRAMs.
My retro rigs (old topic)
Report spammers here!
Reply 6 of 11, by Batyra
The best thing is that they're original. Not any midding stuff... They were described as RIMM but I have one identical already and there is written on them PC133 DIMM 😀
Reply 7 of 11, by dionb
The keying is clearly 168p 3.3V unbuffered DIMM, so it could really only be EDO or SDR-SDRAM, and EDO being used this late in this form factor is pretty much unheard of, so yes, this is almost certainly SDRAM.
Reply 8 of 11, by Batyra
If anyone can help me... OCZ Frost pc150 - blue PCB.
Also known as: Pc 150 Ocz "Blue Ice" Cl2 "Performance" Sdram
I already have OCZ fire on red pcb but I need blue desperately!
HELP!
26.79 KiB
OCZ Frost pc150
Reply 9 of 11, by Batyra
Blue build is in progres. So far I have:
- Blue power supply
- Motherboard: GA-BX2000+
- Graphics Card: Hercules Propher III Ti500 (GF3 Ti500)
- Accelerator: 2x ProVideo Voodoo 2 (blue PCB)
- Soundcard: My precioussss Miro GUS PnP Engeneering Sample
For Cooling for now I've chosen Thermaltake Golden Orb for P3 - it fits golden heatsink on motherboard…
Unfortunately those ram I had are not working… only one stick works rest is unfunctional or detected as half...
And now… GUYS I NEED HELP!!
Blue PCB ram is needed desperately!!!
On Ebay there are but only on pictures - when I asked seller from China he said that it is only reference photo RAM is Green.
There is OCZ Frost or OCZ Ice - don't know exactly name...
I really need it desperately - Please hepl 😀
I can spend really much $$$ on it. (as for ram) 😀
BTW - any ideas what else I can add to this build (of course blue).
Reply 10 of 11, by The Serpent Rider
Repaint modules or order custom PCB?
Aureal Vortex 2 SQ2500?
Reply 11 of 11, by Batyra
Think I found something. 256mb modules dimm pc133 were produced for some brothers printig stations… have to chceck it.
about Aureal Vortex 2 SQ2500? Good idea... GUS for DOS and Vortex for windows...
