Reply 8920 of 31893, by buckeye
- Oldbie
wrote:Two things. […]
Two things.
One, added the same StarTech 5.25" 3.5" drive bay into my Pentium 3 machine, just like I did with my P4 machine.
Two, "installed" SoftMPU (i.e. copy the executable file) onto that same machine and created simple batch files to "run" SoftMPU for either my MT-32 Rev.0 or SC-88 (haven't tested the MT-32 with any DOS games on that PC yet, but I know it works with my modern PC playing Dune II via Dune Dynasty 😀 ). Have a really short look at the SC-88 (in SC-55 mapped mode) playing MIDI music in Doom and Doom 2.
The resulting MIDI music is sent from the SC-88 into an audio switch, and then from there into the "line in" port of the AWE64 Value in the system.
Also, question: Does Doom 2 support the SC-88 (with all of its extra sounds), or does it only support the SC-55?
Appreciate your setup. Curious as to what model your Dell monitor is, does it do well generally for DOS games via DVI hookup or you just use VGA?
