Re: What retro activity did you get up to today?
Postby wiretap » 2018-6-19 @ 17:38
OldCat wrote:
wiretap wrote: If it was me, I would just buy the same 6V Ni/Cd battery, then remote mount it somewhere else in the case so it doesn't corrode on the board again.
No chance in hell I'm using Ni-Cd again. Ni-MH all the way, they don't spill like that.
From my experience, it usually takes about 15 years for a NiCd battery to start corroding. That's a pretty long time, and with it being remote mounted, it would be similar to replacing it with a NiMH battery. But, NiMH batteries still can get leaking and corrosion. Either way, a newly manufactured NiCd or NiMH battery shouldn't be as susceptible to leaking as early generation batteries that we see on older motherboards. I've replaced quite a few NiCd and NiMH batteries at work on a 10-year PM cycle, and none have exhibited leaking problems.
User avatar
wiretap
Postby buckeye » 2018-6-19 @ 21:04
the_ultra_code wrote:Two things.
One, added the same StarTech 5.25" 3.5" drive bay into my Pentium 3 machine, just like I did with my P4 machine.
Two, "installed" SoftMPU (i.e. copy the executable file) onto that same machine and created simple batch files to "run" SoftMPU for either my MT-32 Rev.0 or SC-88 (haven't tested the MT-32 with any DOS games on that PC yet, but I know it works with my modern PC playing Dune II via Dune Dynasty :) ). Have a really short look at the SC-88 (in SC-55 mapped mode) playing MIDI music in Doom and Doom 2.
The resulting MIDI music is sent from the SC-88 into an audio switch, and then from there into the "line in" port of the AWE64 Value in the system.
Also, question: Does Doom 2 support the SC-88 (with all of its extra sounds), or does it only support the SC-55?
Appreciate your setup. Curious as to what model your Dell monitor is, does it do well generally for DOS games via DVI hookup or you just use VGA?
Foxconn Q45M E8400 Core2 Duo 2GB DDR2 800 160GB BFG Geforce 7950GT 512MB 500W XP SP2
Asus P3B-F P3 850 512MB 40GB Hercules 3D Prophet II 64MB Voodoo2 SLI Aureal Vortex 2 400W 98SE
User avatar
buckeye
Postby Nvm1 » 2018-6-20 @ 08:09
I finally found time to find why my asus 386/33-64k motherboard wouldn't boot completely.
The cyrix fasmath FPU made bad contact between some legs and the socket. Cleaning the legs thoroughly made the board boot again :lol:
Now if only I could find the memory expansion board for it..
Does anybody know if one of the doubleclocked upgrade chips works in the asus 386/33-64k motherboard?
Nvm1
Postby Murugan » 2018-6-20 @ 08:59
Had to stop my K6-3 build due to missing parts but started 2 Athlon builds :) I will pick that one up later on.
I'm having waaaaaay too much hardware :(
My retrocollection: Commodore 486SX-25, Commodore 486-33C, Socket 3-5-7 systems,Atari 1040STE boxed,Atari 2600JR boxed,Atari 7800 boxed,NES boxed, Gameboy classic boxed,Amstrad GX4000 boxed,Spectrum Vega,C64 Mini :sweatdrop:
User avatar
Murugan
Postby GabrielKnight123 » 2018-6-20 @ 17:56
I had a motherboard that can take a range of 486 CPU's sitting in the cupboard and tonight was its time for a test if it worked I knew it had a bad leaking battery soldered in so I left it in till I knew it worked so I tried a CPU/Ram/Video card without a case it was just sitting on a table as a test bench and no matter what CPU or ram I tried I could not get even a error code beep, every time I changed the CPU I had to change jumpers I even tried different power supplies I almost gave up when I looked in my spare parts cupboard and I found the exact same motherboard that didn't survive the cleaning process from a leaked battery as well and I found the board I couldn't get working was missing a Bios chip so no wonder nothing worked - palm slap to head - I have now removed the battery, used white vinegar to neutralise anything green and cleaned and got rid of most of the water with a hair dryer and its now air drying.
GabrielKnight123
Postby the_ultra_code » 2018-6-21 @ 02:31
buckeye wrote:Appreciate your setup. Curious as to what model your Dell monitor is, does it do well generally for DOS games via DVI hookup or you just use VGA?
Thanks. :)
Well, that monitor, which I use with both my Pentium 3 and 4 systems, is a Dell 1907FP, which, from what I can tell, is a larger 19" variant of the 17" Dell 1707FP (support page: http://www.dell.com/support/home/us/en/19/product-support/product/dell-1707fpt/research). I got the monitor (along with its original driver CD and an old Pentium 4 Dell PC) from a former teacher when I helped her pull all of her personal files from the Dell PC. While I disassembled the Dell PC and either sold/am selling or threw away its parts, I decided to keep the monitor, and I'm glad I did.
Regarding how I use it, I have it hooked up via VGA to my P3's Voodoo3 3000, and via DVI to my P4's ATI Radeon 9800 Pro 128MB. The monitor has a nice little toggle button on the front of it, so, depending on which retro gaming machine I want to use, I select either "analog" (VGA) or "digital" (DVI), and ta-da!, I can switch between them. :)
While it's a great Windows monitor, I have used it both in MS-DOS mode and with DOS bootdisks, and it works just fine. I might have to use the auto-adjust sometimes with DOS when using its VGA input, because either the display won't line up with the screen perfectly or sometimes it will be way off, but that works 99.99% of the time. If anything were to need any more fine tuning, though, I could manually adjust settings such as the display's horizontal and vertical positions, as well as settings such as pixel clock and phase (the last two I'm not too familiar with; I know though that I had to work with these settings on this other, I think older, VGA-only Samsung monitor, but it has been such a long time that I forgot exactly how these settings impact the display).
If you want to get one yourself, they seem to sell for around $30-ish on the low-end on ebay, from what I see.
User avatar
the_ultra_code
Postby oeuvre » 2018-6-21 @ 03:22
NetVista Sleeper i7 3770, 16GB, GTX750, 2xSSD + HD, XP/7/MacOS 10.13.6
ThinkCentre Sleeper Ryzen 7 2700, 32GB, RX580 8GB, NVMe SSD + HD, 10
User avatar
oeuvre
Postby voodoo5_6k » 2018-6-21 @ 06:08
oeuvre wrote:fun with oemlogo.bmp
Ha, finally some good music here :cool:
END OF LINE.
My retro systems:
1: E4700 2.6|512MB|P5PE-VM|Voodoo5|SB0240|UM-1>UM-550>CM-32L+SC-55
2: P3-S 1.4|512MB|D815EEA2|Voodoo5+Voodoo5 6000|SB0350
3: P4 3.4EE|4GB|P4C800-E|FX 5900 Ultra+Ti4600|SB0466
4: X5470 3.33|8GB|P5Q-E|GTX 580 3G|SB0886
User avatar
voodoo5_6k
Postby root42 » 2018-6-21 @ 08:21
I built a CMOS battery for my 286 mainboard. I put everything on a small board with a diode attached, against charge protection. I used a SAFT 2450mAH Lithium battery at 3.6V. At the 1uA the CMOS draws, I get a voltage drop of about 0.1V to 3.5V. This should be plenty and last for many years.
Todo: I will print a case and attach it with some velcro in the (to be purchased) case.
Picture:
YouTube video:
https://youtu.be/seCoC2AcHqs
Soldering, retro game reviews and more on YouTube and Bonus videos
Me playing games on my 286 and on my Sega MD2 on Twitch
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, schlae AdLib, PC MIDI Card + SC55MkII, XT CF Lite, OSSC 1.6
User avatar
root42
Postby oeuvre » 2018-6-21 @ 12:48
HAMMER SMASHED PENTIUM 4
User avatar
oeuvre
Postby appiah4 » 2018-6-21 @ 13:04
Incidentally, the only good Pentium 4.
(AthlonXP forever)
1989:A500|1M|ACA500+|C1084S
1992:HIPPO-VL+|U5SX-33|8M|GD5428|CT2290|S2
1995:P5I430VX|P133|32M|Trio64|V1|CT3980/32M
1998:S1573S|K6-2/400|64M|RagePro|V2/SLI|CT4500/32M
2001:GA-6OXT|PIII-1200|512M|GF3Ti200|MX300
2004:K8V-D|3700+|2G|X1950P|SB0350
User avatar
appiah4
Postby dionb » 2018-6-21 @ 15:11
appiah4 wrote:
oeuvre wrote:
voodoo5_6k wrote:Ha, finally some good music here :cool:
(AthlonXP forever)
Cue Guns'n'Roses: crack crack cracking on Athlon's core :dead:
(mind you, I ran Athlons back in the day too - P4 was overpriced and overheated - but it was with the Athlon64 X2 and later Core2Duo that things really went into high gear)
User avatar
dionb
Postby wiretap » 2018-6-21 @ 15:46
Went on my first ever thrift store run. Sadly disappointed, haha. I found a copy of The Sims 2: Pets on PC-CD, and a bunch of 15-17" Dell LCD monitors that were all scratched up. No purchases this time. But it was fun seeing weird stuff that people donate for resale.
User avatar
wiretap
Postby bjwil1991 » 2018-6-21 @ 16:21
Wait until fall or winter. You'd be surprised. My thirifting adventures has been slim for a while and some don't take credit cards or their credit card machines are still broken since December. Got a huge haul of computers (2 of them disassembled and in my parts dresser drawer) that needed major work (RAM upgrade, new HDD, new CD-ROM drive), or just minor work (new clock battery, or just a fresh OS install on a perfectly running HDD). PCs I bought at thrift stores (including bidding sites) from 2016-Present:
1) IBM ThinkPad R40 2682 (now has 1GB RAM), Windows XP Pro SP3 32-bit
2) HP Pavilion N3350 (goodwill bidding site), no OS presently (HDD is in my Socket 7 machine using the 2.5" to 3.5" IDE kit)
3) Packard Bell Pack-Mate 28 Plus, MS-DOS 6.22/Windows 95C (only needed a new battery, and installed/upgraded parts)
4) Dell Dimension 4550 (4 bulged up caps, still works), no OS presently
5) Dell Dimension E510 (had Windows 7 Ultimate, DBAN'd the drive, now has linux)
6) iMac G3/600 (HDD went south as well as the CD drive), replaced the HDD with a 200GB one, slim SuperDrive kit, RAM upgraded to 768MB, and replaced PRAM battery, running Mac OS X Tiger 10.4.11 and Lubuntu 16.04.3 LTS
7) HP Pavilion 7955 (parted)*
8 ) 2 Commodore 64 (one needs a new RF modulator or logic board for the A/V out only, the other works great and has an aftermarket case)
9) 2 Dell Inspiron 600m laptops (one has issues, no OS due to HDD issues, the other works without problems, running XP Pro SP3) that need better wireless cards (802.11b isn't functioning any longer)
10) iMac G4/800 (re-installed Mac OS X)
11) HP Pavilion A706N (parted)*
* Kept the internals (motherboard, RAM, CPU, I/O backplane, expansion slot covers, internal cards (modems, wireless cards, USB/FireWire cards), HDD, CD-ROM drives, ribbon cables, PSUs)
C64, WheelWriter 10 Series II QuietWriter 8, Pack-Mate 28 Plus, K6-2/300, Pavilion N3350, iMac G3 & G4, Socket 462, 2x Inspiron 600m, Athlon 64, Dimension 4550 & E510, ThinkPad R40, Presario C700, ASUS X54C, Raspberry Pi B+, 2B-3B+, Custom FX-6300
User avatar
bjwil1991
Postby NamelessPlayer » 2018-6-22 @ 01:41
I got all my caps yesterday, and today, I set about recapping that A4000.
Well, it certainly doesn't work any worse than it did before, as far as I can tell, though I'm not sure if it works any better, either. Maybe two of the Fast RAM SIMMs really are suspect enough that I'll have to just run it with the usual 2 MB of Chip RAM and only 8 MB of Fast RAM. Problem is, I don't have any other 72-pin SIMMs lying around.
It's also a painful reminder that I really need some better gear for SMD soldering, because carefully aligning a capacitor to solder it down with a conventional iron gets rather tedious and requires nerves of steel. I'd normally use the hot air blower on the local makerspace's soldering station, but they don't have a PCB pre-heat platform to set the board on, nor do they seem to have any narrower nozzles I can use for this particular purpose.
One of those ultrasonic cleaners would be great too, just to get all the flux and any traces of alkaline electrolyte and battery fluids off that all my isopropyl alcohol scrubbing may have missed.
At the end of the day, though, it's still a working A4000 that keeps its time after I soldered in a CR2032 holder, saved in the nick of time from being another Varta barrel battery victim.
User avatar
NamelessPlayer
Postby liqmat » 2018-6-22 @ 02:58
Not computer related, but an incredible find for our family. Found two very early 16mm color movie film reels from the late 1930s while helping my elderly mother clean up her house. I did not realize film reels came in color that early in the 20th century especially home movie reels. My late grandfather filmed all of it apparently and it will be interesting to see what's on them. I checked a few frames under a light and the film looks to be in good condition. Dropping it off tomorrow to get transferred to digital.
User avatar
liqmat
Postby TheAbandonwareGuy » 2018-6-22 @ 05:58
bjwil1991 wrote:Wait until fall or winter. You'd be surprised. My thirifting adventures has been slim for a while and some don't take credit cards or their credit card machines are still broken since December. Got a huge haul of computers (2 of them disassembled and in my parts dresser drawer) that needed major work (RAM upgrade, new HDD, new CD-ROM drive), or just minor work (new clock battery, or just a fresh OS install on a perfectly running HDD). PCs I bought at thrift stores (including bidding sites) from 2016-Present:
Why on earth would you part out working OEM systems? Those aren't customs builds, they are unique designs that will someday be either uncommon or in the case of alot of obscure models entirely gone. I think HP Pavilions are some of the better looking machines that were produced too.
https://www.youtube.com/channel/UCuFY6Z ... 2tV8b00x_A
1996|P200MMX|64MB EDO|Virge DX 4MB|SB16 OPL3
1999|P3 933|384MB SDR|GF2 Ultra 64MB|CT4620
User avatar
TheAbandonwareGuy
Postby TheAbandonwareGuy » 2018-6-22 @ 05:59
liqmat wrote:Not computer related, but an incredible find for our family. Found two very early 16mm color movie film reels from the late 1930s while helping my elderly mother clean up her house. I did not realize film reels came in color that early in the 20th century especially home movie reels. My late grandfather filmed all of it apparently and it will be interesting to see what's on them. I checked a few frames under a light and the film looks to be in good condition. Dropping it off tomorrow to get transferred to digital.
My understanding was that no one had developed Kodachrome film since something like 2009?
User avatar
TheAbandonwareGuy
Postby ssokolow » 2018-6-22 @ 07:46
the_ultra_code wrote:Well, that monitor, which I use with both my Pentium 3 and 4 systems, is a Dell 1907FP, which, from what I can tell, is a larger 19" variant of the 17" Dell 1707FP (support page: http://www.dell.com/support/home/us/en/19/product-support/product/dell-1707fpt/research). I got the monitor (along with its original driver CD and an old Pentium 4 Dell PC) from a former teacher when I helped her pull all of her personal files from the Dell PC. While I disassembled the Dell PC and either sold/am selling or threw away its parts, I decided to keep the monitor, and I'm glad I did.
Huh. I've got one of those as the right end of the three-monitor spread for my main machine. It was given to me by a friend because the power button had broken and I didn't know how to solvent weld at the time, so I ended up MacGyvering up a solution by...
  1. Drilling a hole over the actual pushbutton
  2. Sawing off the top of a clear push pin
  3. Cutting a shaped piece of electrical tape to hold it in
  4. Using hot glue as a translucent window on the old power button hole.
Also, I found another nostalgic, elegant, and useful shell extension in my old DVD+R backups and uploaded it: Something to add the Registry as one of the namespaces in My Computer.
Internet Archive: My Uploads
My Blog: DOS & Win16 programming resources, Free Installer Creators for All Eras
My Rose-Coloured-Glasses Builds
I also try to announce anything retro-relevant on on Twitter.
User avatar
ssokolow
Postby TheAbandonwareGuy » 2018-6-22 @ 09:17
I'm listening to Van Halen's "5150" on a Dolby HX Pro encoded cassette. This stuff sounds fantastic.
User avatar
TheAbandonwareGuy
PreviousNext
Who is online
Users browsing this forum: Exabot [Bot], frudi, Google [Bot], RichPimp and 13 guests
