Reply 60 of 214, by dr.zeissler
I bought a Gotek for my EuroPC. I can tell you that it works, but it is slow!
It's perhaps as slow as the loading from a real floppy-disk, but you can't hear the disk-acess.
It's not a thing that I would give away my xt-ide in the single isa-slot.
I currently use CGA instead von MDA because I use a !084 with both C64 and EuroPC connected
and I can switch on the front between both machines... that's nice.
Composit CGA that is used in early agi-games (ll1,pq1,sq1,kq1,etc.) is monochrome on my
1084 but it looks much nicer then the real cga-color-mode for RGB which is truly ugly btw.
https://books.google.de/books?id=lB4PAwAAQBAJ … 20larry&f=false
