First post, by twilliamc
So I chose this motherboard for a variety of reasons. VLB slots, CMOS replaced, WINbios, etc.
1.67 MiB
However, since booting up an using the thing, it appears to have a serious flaw. It kills any CMOS battery I have in it. After a day or so, the CMOS will drain well below 1.5v and the motherboard will lose all its settings. Any help would be greatly appreciated. I have already checked the CMOS discharge pin, JP39 and it is set to pins 1 and 2 as normal. The motherboard in question is a V4S471/G Ver 9.0 or so I was told by the ebay seller. Online manuals seem to concur. Any tips for diagnosing this poor guy? I have included a close up of what appears to be corrosion on a diode and the AT keyboard port. Any help would be greatly appreciated. I have a soldering station and decent skills. If I need to desolder the battery terminal and clean it up, I am more than willing to do it in order to keep the board in the land of the living.
619.03 KiB
Unnamed: 486DX4 @ 120MHz, 16MB, 2GB, 2MB VGA, SBPro 2.0, DOS/W3.11, W95
PC-65:P3 @ 800MHz x2, 512MB, 128GB SSD, Voodoo3, SB Live!, Win98SE
Reply 1 of 10, by tpowell.ca
Some CMOS batteries are designed to be recharged such as the cylindrical types often found on 386/early 486 motherboards.
You can't just install a lithium CR2032 non-rechargeable battery in its place.
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 2 of 10, by quicknick
That ^^ is spot on. Judging by the corrosion and the CR2032 holder patchwork, I say the motherboard originally had a barrel battery (and the circuitry to charge it). You can check for that with your DMM by powering up your board without a battery in place, there must be no voltage present on the holder contacts. If there is, this means your non-rechargeable battery is being charged, and you're lucky it died gracefully without spilling its guts on the board 😁
Usually there is a diode that can be removed in order to prevent charging, you'll need to poke around to find exactly which one is it. Anyway I recommend desoldering the battery holder and thoroughly neutralize the green goo (use vinegar, water, isopropyl alcohol), else in time it will eat your board.
Reply 3 of 10, by twilliamc
Correct you both are. Looks like I have work to do this weekend. I powered up the board on the bench and the battery terminal was pushing out 4.7v. As you said, I got really lucky that things did not get explosive. I will get the terminal out and clean the board up. As far as Diodes go, I can see two on the board near the battery and neither show continuity with the terminal. Is that a thing? Or should follow some traces to determine which one?
Reply 4 of 10, by quicknick
There is also a series resistor to limit the charging current, so the circuit could be as follows: (+5v)-----|>|------|===|-----(battery+)
Where the first thing is a diode and the second a resistor. You can remove either/both.
Reply 6 of 10, by dionb
Personally I'd suggest getting the battery off the board altogether. Three AAA rechargeables in a separate battery holder are overkill in terms of capacity, but cheap, easy and deliver the correct voltage. Just solder in two pins where the CR-2032-holder is currently located and put the batteries somewhere else (preferably below the motherboard so if they ever do leak, the board is safe).
Reply 7 of 10, by root42
I added a non-rechargeable Lithium 3.6V AA battery to my 286 the other day. Just put a small diode in series with it (polarity!) to stop the mainboard from charging it, and you're done.
I documented it on video:
https://youtu.be/seCoC2AcHqs
You can velcro the whole contraption inside your case. Maybe even put it in a small 3D printed enclosure, to keep it safe from shorting out or to protect against possible leakage, which I doubt is a problem with the lithium batteries.
YouTube and Bonus
Reply 8 of 10, by twilliamc
I desoldered a single pin of D4 on the left side of the board after tracing the negative line that way... The cmos recharge voltage dropped from 4.7v to ~1.4v. Am I heading in the right direction? Should the cmos voltage drop to 0?
Reply 9 of 10, by twilliamc
I believe I have found the resistor and the diode. I removed both and the battery terminals now read -2.7v when the board is on. Is this what I should be seeing?
EDIT: pretty sure it is not. I checked another board which gets ~0v when powered on.... More research needed.
Reply 10 of 10, by quicknick
I've done this mod on two or three motherboards, and as far as I remember the voltage was pretty close to zero after removing the charging diode. Reading a negative voltage doesn't seem right to me, but maybe there is a -5/-12V trace nearby and you're picking leakage from that. You can also check if there's a charging current at the battery terminals using your DMM on the (milli)ampere range. Before modding, my boards had a charging current of around 4 or 8 mA, cannot remember exactly. Was 0 uA after removing the diode.
