Reply 9280 of 31262, by Cyrix200+
- Oldbie
I have been acquiring stuff for about 3 years now, I desperately needed to do some 'inventory management', so I have been getting rid of stuff. So far only the things that went to the recycling center (some defective core(/2)(/duo) OEM stuff, a few motherboards with physical damage (broken-off slots, deep scratches). When I brought everything to the recycling center, I spotted 2 beige systems in the bin, one AT with a 3-digit MHz display and a 8x CDROM and a more modern beige ATX case with a soundcard in the bottom slot (ie. ISA). I tried taking them but no dice, the guy wouldn't budge. I even tried a little bribe. What a waste.
I also decided that my cut-off for harware will be Pentium III / Slot A. Nothing newer than that. But maybe some Socket A also. I just don't care about anything newer. Also, I need to use or at least test my hardware.
No more hoarding! No more buying cheap boxes of old stuff! (let's see how long I can do that haha).
EDIT: also I don't need to keep 9 Sound Blaster 16, 5 AWE32, 7 AWE64. Or 26 S3 Trio/Virge PCi variations. Etc.
1982 to 2001
