Reply 9480 of 27625, by 0kool
Got tired of constant CPU cooler howling in my P133 rig on every power-on. Thanks god they still make smaller fans. I had to wait for almost a week, since the local store doesn't keep it in stock. Supposed to be high-end, Noctua level. It even has 2-pin connector. If it's anything I expect it to be, I'll get a few more to upgrade other machines.
Update:
Yeah.. 😒 Even though the size of the fan matches socket 7 heatsink perfectly, somehow I ignored the fact that in most cases the fan should be 5mm smaller to fit inside the heatsink. I'll try longer screws or some improvised bracket mounts. I don't believe I've seen 45mm around and 40mm just doesn't give me the right vibes.
Update 2: "Longer screws". Back in business!
