First post, by treeman
so the situation looks like this, I am currently using the vibra 16 isa in my 486/586 system. I am upgrading the AT psu to a ATX using a standard converter. However the vibra 16 uses -5v (there is a 5th pin on the back from the end)
So in my parts collection I found the opti which doesn't have the 5th pin so doesn't use the -5V rail therefore would be a simple swap and drop with the atx psu.
I don't know much about sound cards so I am hoping to get a general idea if these cards are far apart. I have a feeling the vibra 16 is a better card. If its not a great difference ill put the opti in and easy money.
However if the vibra 16 heavily outweighs the opti there is option number 3. Order a -5v convertor (CONVERT 20 PIN (NO -5V) TO 20 PIN WITH -5V & OPTIONAL ON/OFF SW)
Appreciate any feedback and advice
Reply 1 of 8, by appiah4
The former is one of the better Vibras out there, being a Vibra it has a very low noise floor and has a genuine OPL3, but its MIDI is bugged. As an OPL3 card, it is perfect. The second is an Opti 82C931 card, this is a very cheap OEM chipset (on a rather cheap OEM card with poor noise levels), it has poor OPL3 clone integrated to the chip (unlike the Opti 82C930 and 82C929 chips that lack one, and are often found alongside a genuine or clone OPL3 chip) but it's MPU-401 is not bugged so it is a better option for using with a Wavetable daughterboard or MIDI device.
82C931 OPL3 example: https://www.youtube.com/watch?v=ju-3c5tXNqY
Pick your poison.
Reply 2 of 8, by treeman
thank you very good answer, something I was kind of expecting as there is never a straight forward choice but it confirms me hunch, keeping the vibra 16 I think is the way to go for me. Doing it the hard way usually gives a better reward.
Time to order or try make a -5V converter
Reply 3 of 8, by cyclone3d
If you are in the USA, it is much easier to just order an adapater for the -5v.
Look up seller "antronst" on eBay.
https://www.ebay.com/usr/antronst
I've ordered a bunch of ATX to AT adapters with -5v from that seller. Can't beat the price either. You can also get ATX to ATX with -5v added.
Edit:.. didn't notice that you already referenced one of that seller's listings.
Do you even need -5v for either of those cards?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 8, by appiah4
I do not think Vibra cards need -5V..
Reply 5 of 8, by treeman
yes I actually found the adapter link from a post you did a year ago cyclone3d so thanx for that!
Yeah you guys are right all I did is check if there is a 5th pin on the isa slot looking from the back. I have another similar card that had issues with a atx converted and the 5th pin was present but nothing is more accurate then actually trying it out. I will hook up the atx psu and try it out but chances are ill be ordering that adapter.
Unfortunately I am in Australia but most stuff for retro I have to order from Usa Europe or China anyway
Reply 6 of 8, by treeman
actually while we are on the topic I pulled out the isa card I. recently lost functionality on my 386 system when switched over to atx as well. Its a vibra 16 too!
and yes I just did notice some rusting in a few places so will clean it.
so perhaps this will give the previous 2 cards a better run for their money? how is this vibra card compared to the first one?
from my reading on vogons I was under the impression that 5th pin being present (pic2) means it draws -5v which both the vibra cards have but opti doesn't
Reply 7 of 8, by appiah4
That is a very peculiar Vibra 16S, I've never seen a non-PnP one.. They usually cone with a CT1705 chip for PnP functionality, yours is a straight up non-PnP Vibra with an OPL3 chip, quite possibly one of the least noisy ways to get true OPL3 non-PnP Sound Blaster 16 sound on the ISA bus, it is a very nice card for older systems (486, 386, etc).
Reply 8 of 8, by treeman
great! I think we have a winner then. its going in my 5x86 amd system which is dos only so good match.
I'll put it see what happens but most likely will need the -5v adapter
