First post, by buckeye
Ok it's official, I'm obsessed with this game! Problem is I can't seem to get proficient with the controls relative to the amount of time I put in. Currently using an Xbox 360 pad without mapping software (tried JoyToKey but it wore my patience out). What do you TR1 jocks out there recommend for "owning" this game - keyboard/mouse, joystick, gamepad type and etc? Currently playing the game using Glidos in windows XP.
Reply 1 of 5, by dr_st
I don't think that game has anything that requires analog precision, does it? If it's all digital, then anything will go - gamepad, keyboard, stick; whatever works for you.
I do recall the controls were pretty sluggish. Not Prince of Persia 3D grade of sluggish, but not far from it.
Reply 2 of 5, by Crank9000
I play the classic TR's using a playstation emulator and I'm not sure have I ever even tried them on PC, but knowing how the game controls I would recommend either using keyboard or some other controller than x360, their d-pad is pretty bad.
Edit: Oh, and in case you actually tried to use the analog sticks for control, forget it. Use digital only.
Reply 4 of 5, by PTherapist
I literally cannot play those games properly with anything other than the keyboard. Even the later Angel of Darkness which supported mouse, I stuck with just the keyboard.
Those controls become 2nd nature after a while. I can't get used to playing console versions with a gamepad.
Reply 5 of 5, by buckeye
I guess it's easy to forget this game came out in 96 or whatever. I'll have to be patient and just keep working it with the keyboard.
