I received the above sound card yesterday.
What a terrible mistake buying this was, thankfully i didn't pay much.
While it does have an OPL3, it is hobbled by the rest of the card that makes me think that they simply didn't care what it sounded like at all. Terrible noise floor, bad distortion with the vibra pre-amplifier, this is a sound blaster 16 you should run far from. The output on this is so bad, I simply can't bring myself to actually use it in any computer I own. What a piece of trash, it has a wavetable header but it would be a terrible waste of money to connect anything to it.
It was so bad, I'm probably going to avoid buying all sound blaster 16's in the future. Expensive and overrated for the most part. What I did do, was buy a Yamaha YMF719E-S based ISA card. That should work a lot better.
