Reply 26300 of 58450, by dionb
- l33t++
wrote:[...]
Just noticed that one of the cases is just like the one I found recently - contained a UMC PCI/VLB motherboard with an AMD DX100. Shame it doesn't have an LED display for the Turbo speed.
Are you sure it doesn't? Can't look right now as there is a pile of other systems on top of this one (FWP 😜 ) but I have the distinct feeling there's one behind that black panel above turbo & reset.
wrote:[...]
This has to be the single most interesting bit of hardware I think I have seen on here. Perspex case is one thing... windows (no punn intended) on the components themselves are another entirely! Congrats.
Apparently this was used as an eye-catcher at computer fairs. It's entirely possible I might even have seen it in action, as there are some materials dating to 1998 which was around when I started to become a regular, and I certainly remember similar things. That date would also explain the very low prices on labels attached to some of the systems, the equivalent of EUR 20 for a 386DX40. Any earlier and it would have been worth more, any later and no one would be interested at any price - which I suppose is how these things ended up in that attic.
That 5150 clone case... does it have a recess for a badge? All those style cases I have seen all have the same sized recess for the badge, which does not fit the I----B----M badge on there. I've not seen the IBM logo strecthed like that, but given the 'perspex' item this guy had, maybe it is some form of prototype itself? who knows.
It has a recess for a badge - exactly the size of the "I B M" logo, so much wider than regular IBM badges.
Are those PS/2's MCA?
The Model 55 SX is MCA, the Model 30 286 is ISA.
Talking of that stuff, here's the software/documentation:
Nothing too spectacular. Sealed MSDOS 5, MSDOS 6 Upgrade & Central Point Backup 7. system manuals for Philips PC and Vendex Headstart systems, Targed-branded DR-DOS 6 manual + install media, a nice Spinrite 2.0 manual + media set, and various manuals & driver disks. If I have time I'll see if there's anything urgently needing uploading.
