Reply 10540 of 30908, by amadeus777999
Great job, liqmat! Hope it all goes up to archive.org. One can get quite nostalgic thinking about those little companies who once were a small part of a "booming" industry. This thought more often than not crossed my mind when I was watching Computer Chronicles and somebody presented his/her product.
--- Cut ---
I had a PC Partner SS7 board laying around with a P55C @ 280mhz which was nice but felt kinda off. Came across a K6 III 400 by accident and now the setup is complete. I disabled the 2nd level cache on the board so that I can drive 133mhz fsb which "eliminated" ony weakness of SS7 system - relatively low memory performance.
The K6III is now running at 133x3 and overall speed is pretty swell. "Perfect" machine for playing more sophisticated Build games like Blood. Not a fan of he K6 but in this case a great product to lend a finishing touch to a speedy system.
Reply 10541 of 30908, by brostenen
Finished up the last thing on my 500 refurbish project. I am only talking about functional things. Or things that makes it a fully working machine. I still need to fix up the cosmetic part. It is now ready to be used again.... Gave it a memory upgrade as well. (and take some nice pictures, when it is 100% finished). The cosmetic part will however not be possible before summer. I need warm and dry weather for the paintjob, as I will be doing it outside.
https://to9xct.blogspot.com/2018/09/my-amiga5 … sh-project.html
EDIT:
A few members here on Vogons have said that it was a NO-GO and I would kill or destroy the plastic when using liquid acetone for welding. To that I can say that it holds up beautifully. The structure are like new and nothing have melted more than it was supposed to melt. It simply works. There are only two things to take into acount when working with liquid acetone. One is to use a tiny amount, and the second is that you need to work extremely fast.
I can't stress this too much... Work fast and be gentle with the amount of acetone used.
Reply 10542 of 30908, by canthearu
Finished restoring the old 286 I bought a week and a half ago.
Previously I had:
a) Stripped down the system, and removed motherboard.
b) Removed battery from motherboard, clean remaining corrosion, reinforced one track with solder and used a wire to repair a second trace damaged by corrosion. Removed the remains of an exploded tantalum capacitor.
c) Pulled apart power supply and give basic clean on the inside.
d) Test floppy drives. The 5.25inch drive worked fine. The 3.5inch drive was non working properly.
Today, to finish the job:
a) Washed the case completely in the bathtub. Case is in reasonably good shape for a 30 year old case.
c) Repair 3.5inch drive with new capacitors, as existing capacitors read very bad ESR. This fixed the drive, although the new capacitors are a bit large and do not quite fit.
c) Create replacement CMOS battery pack, using and 4xAA battery pack and installing a wire in one of the battery position. This makes it a 3 battery pack.
d) Reassemble computer into clean case. Install with new battery pack and add sound card to the mix.
e) All tested and working. Fix front panel display to show 12mhz when turbo on, and 8mhz with turbo off.
Now I should redo the software on it, installing a fresh copy of DOS and Windows 3.1.
Computer specs:
286-12mhz
4meg RAM, in DIP sockets.
50meg Quantium Plus Impulse IDE hard drive (no bad sectors)
1.44meg floppy
1.2meg floppy
IDE/Floppy ISA card (16-bit)
Serial/Parallel ISA card (8-bit)
Trident 8800 VGA card (8-bit) (maybe this can do EGA too, it has a 9-pin plug as well as the standard VGA plug)
ESS-1869 Sound card. (16-bit)
This computer was definitely worth picking up and restoring.
Reply 10543 of 30908, by liqmat
canthearu wrote:
Finished restoring the old 286 I bought a week and a half ago. […]
Previously I had:
Computer specs:
286-12mhz
1.44meg floppy
1.2meg floppy
Nice job! All the bathtubs in my life have seen a computer or two. Everything, but software, goes into the bathtub. It's a cleansing experience.
The attachment fatcattub.gif is no longer available
Reply 10544 of 30908, by Predator99
Continued working on this A2088 XT bridgeboard. Got it in a scrap lot it it didnt look good:
The attachment IMG_0094r.jpg is no longer available
Thats the condition now:
The attachment IMG_0129r.jpg is no longer available
I washed with water and replaced the 2 PLCC sockets on the left as they were totally corroded. Also replaced the Caps.
But still didnt work. Tried with Supersoft and it shows me 2 damaged RAMs.
Therefore I desoldered all RAMs and replaced with sockets.
The attachment DSC_7745.JPG is no longer available
The attachment DSC_7763r.jpg is no longer available
Now Supersoft is happy ...
The attachment DSC_7765r.jpg is no longer available
...but it still POSTs only every 5th attempt or so.
Out of ideas at the moment...
Reply 10545 of 30908, by canthearu
I'd test/replace the electrolytic caps on it.
Intermittent faults are very often due to these infernal capacitors.
Then if that isn't the problem, I'd go over it carefully looking for poor or cracked solder joints.
Reply 10546 of 30908, by luckybob
+1 for canthearu
Reply 10547 of 30908, by Baoran
canthearu wrote:
I'd test/replace the electrolytic caps on it. […]
I think he already mentioned that he replaced the caps.
Reply 10548 of 30908, by appiah4
brostenen wrote:
Finished up the last thing on my 500 refurbish project. I am only talking about functional things. Or things that makes it a ful […]
EDIT:
I have been following this project for a while, and as a fellow A500 lover, I commend you on everything you've done to it.
Reply 10549 of 30908, by canthearu
You are right, the caps have been replaced.
Reply 10550 of 30908, by dionb
Been having fun with ancient hardware.
Booted up an Am386SX-33 that worked last week (for the first time in at least two decades). This week the PSU had completely died. Probably dead caps - put on the to-do pile. Then hooked up a known-good PSU. I wanted to test some I/O stuff.
First up I wanted to see if I had any ISA IDE controllers that could handle ATAPI. First hit - the no-name WD37C65C-based card already in there immediately recognized my ATAPI CDRom. That was great news. Then tested an ISA SCSI controller (AHA-1542C) I received recently. I needed to move the ROM BIOS address from default DC000H to D8000H (not sure what it was conflicting with...) before it would work, but after doing that it was more than happy. It enabled me to test some ancient drives. Turns out my 21MB Miniscribe 8435S is in perfect working order, but my 668MB Micropolis 1624 doesn't even spin up or get recognized by the SCSI BIOS. Damned shame... also hooked up an Archive Corporation Cartridge Tape Drive model 5945C. It gets detected and makes all the right noises, but lacking the correct software for it, I can't take it any further than that.
Also I wanted to test some ST-506, specifically a Seageate ST-251-1 (43MB MFM) drive. It sort of seems to respond to stuff, but needs initializing with my DTK MFM controller, and I don't have the right tool for that. Oh well, stays on the to-do pile.
Finally I had a look at a 486 that seemed dead. Looks like a bad case of battery corrosion - maybe I can fix something but not too optimistic. Am fairly happy though: it had 4x 30p SIMMs. I assumed they were 1MB parity SIMMs. I was right about the parity, but not the 1MB - this is 4x 4MB. That's a lot better than a kick in the teeth 😀
Reply 10551 of 30908, by Mister Xiado
Since I've hit roadblocks in the PC arena, I've been trying to get information on the gamepad for the Philips CDi, but the encoder is not coming up anywhere. All that's printed on the chip is:
© Logitech 93 Ⓜ
330078-00G1
0E31AQLEL9407
16 pin dual inline package. Nothing turned up when looking for even partial values on AllDataSheet, or through general searching. Based on the Ⓜ, it's probably a Motorola? There's a dire shortage of affordable CDi controllers, and I had intended to see if I could construct a few, but this is changing from "research needed" to "scrying through unicorn entrails".
Also installed a CR2032 socket in a Super Nintendo game, in advance of preparing to perform techromancy on some dead DALLAS chips; something I really would rather not do.
Reply 10552 of 30908, by brostenen
EDIT:
Thanks 100 times... 😀
I am by far and no professional repairman at all. Yeah... I am thinking about people like retromancave. On the other hand, then I am extremely surprised how simple and durable an Amiga500 really is. A 486 VLB board is actually more confusing to figure out I think. You know. What is what and what does what.
In the next couple of months, I will be making a new blog post about the other 500 that I have in the closet. That one is the 500 that I will be keeping for my self. And it will have a broad selection of upgrades. What is missing, before I can use it, are a set of socket risers or spacers if you like. And I need to find a way of tapping into the floppy power in order to get an internal CF card solution running in that Amiga500.... Not saying more. It's going to be awesomme.
Reply 10553 of 30908, by Predator99
liqmat wrote:
This past week has been a week of archiving a large amount of vintage software for preservation purposes. Updated my year long C […]
This past week has been a week of archiving a large amount of vintage software for preservation purposes. Updated my year long Cardinal SNAPplus archival project with more found drivers, manuals and software. Imaged twenty hard to find Wang APC software & systems disks. Categorized, combined and labelled two large ALR server file and document archives. Finally, I am in the middle of building an archive for the long forgotten Tempra line of software from a long ago defunct company called Mathematica, Inc. Found two more sealed products from them and have been scanning and imaging for the last few days. One of the products is so rare I didn't even know it existed until I saw it on Ebay. They were mainly producers of DOS multimedia content creation software before they went belly up. Found a Windows version of their software and this must have been released just moments before they went under because I never knew about it until now and I used their products extensively back in the early 90s.
One of the many challenges of archiving old 5¼" floppy disks is possible disk warping like the disk you see below. Luckily the magnetic disk itself was not warped and only the casing was. What I had to do to get the data off was slowly and carefully move the disk in the disk drive as WinImage read the disk. When WinImage encountered an error I would have to press down on a different part of the disk casing to flatten it as best as possible and hit "retry" in WinImage. Eventually, with a lot of patience, I got a complete image off the disk. What some of us do for historical preservation. So worth it though.
It's kind of hard to see in this light, but you can see the disk casing is warped. Mr. floppy drive was not happy about this.
Good work! But why didnt you remove the magnetic disk from its case and put it in another one? Of course, you would have to damage your disk.
I think it should also be possible to put only the disk in the drive when you have its top cover removed.
Reply 10554 of 30908, by Predator99
Indeed, I already replaced them. Bad caps are a good explanation for that behaviour. I also noticed that it preferably POSTs when it has been turned off for some hours. After that, with each powercycle it gets more unlikely that it works...
Reply 10555 of 30908, by brostenen
Can you check if the PLCC gets extremely hot, when it stops working? Or try cleaning each pins on all 3 PLCC's....
The blue components. Are they Cap's? And if so, have you replaced them as well?
These are the things I would check out next. Or simply check if heat makes any socketed chips (PLCC as well) kind of loose contact due to expanding from heat or something like that.
Reply 10556 of 30908, by Predator99
No, I just kept it running while it hasnt POSTed. All ICs are cold. When it POSTs, everything has normal operation temperature.
Yes, there is some corrosion on the PLCCs pins. Maybe a good idea to continue...
No, havent touched the blue components. And I will not, these are too many and they dont look that bad 😉
I dont know how these things work, but I assume the error is on the Amiga side not the PC side.
Reply 10557 of 30908, by brostenen
Predator99 wrote:
No, I just kept it running while it hasnt POSTed. All ICs are cold. When it POSTs, everything has normal operation temperature. […]
Hmm... If the blue ones is, and I think the are, tantelum caps. Then they might be on their last.
Do you get any issues with the Amiga, when you are running without the board?
Reply 10558 of 30908, by RandomStranger
I was planning of sort of finishing my early 2000's dream PC.
I wanted it to have a:
Radeon 9800 Pro 128MB
ASUS P4V800D-X Motherboard
1GB DDR400 RAM
Pentium 4 3.2GHz (Northwood)
I had a Celeron D 2.8GHz in the motherboard and since I replaced it with the Pentium, the system doesn't boot. Neither with the Pentium, nor with the Celeron.
If I turn it on, the fans start, but the screen is black and it seems to be dead. I can't make it to give any error codes.
So installing a CPU and a Windows XP then replay some of my older favorites turned into finding out if the motherboard really is finished or not.
I tried different graphics cards and tested the PSU (500W FSP) with a different motherboard. Nothing on the motherboads seems visibly bad
Yesterday was much better. I tested the graphics cards from here.
Everything worked perfectly and finally I was able to finish My other early 2000's PC with the Tualatin mentioned above, 40GB Maxtor HDD, 512 MB SD-RAM and the GF4 Ti4200.
It is surprisingly agile compared to my Coppermine P3-933 + Radeon 8500LE + 512MB SD-RAM + 20GB Maxtor build. Even more than what I'd find reasonable. I guess I should install a fresh OS on this one too.
Reply 10559 of 30908, by liqmat
Simple answer. Because I didn't have to and I am not into damaging what I am trying preserve.
