Reply 26400 of 58450, by yawetaG
Just received this bugger:
Kawai GMCat, basically a Kawai GMouse (very cut down GMega LX) grafted into a mini keyboard MIDI controller. Some details:
It can be powered via a power supply or with 6 AA batteries, and the output is almost noise-free (some instruments are a bit worse than others, e.g. the electric guitars). Some of the instruments do weird things when sustaining the sound - the samples seem to be very short and the attack portion repeats. There are also a few instruments that use the names of the GM sound set, but are quite different than what they should be. No velocity sensitivity though.
