Reply 10580 of 31833, by ultra_code
bjwil1991 wrote:
That looks interesting. Which system do you use for the NAS OS? I remember using NAS4Free on my Socket 7 machine and a worn down Compaq Presario C700 several years ago.
I'm using OpenMediaVault on an Odroid HC2 from HardKernel. I used the following guide by Explaining Computers to help me set up the system, and then did some additional things to set it up as so (adding FTP support). A very simple, "cheap", small purpose-built one-drive NAS solution, I would think (the WD Green 2TB HDD I got for $20 USD at a local buy-sell-trade store, and the whole NAS setup (minus the SD card for OMV, which I saved some money and bought it off Amazon for $6.19) I paid $84.10 for straight from HardKernel).
Also, question: Has any one had any experience with the Creative Extigy external USB sound device? I saw one at that same buy-sell-trade store, and was wondering is it worth picking it up for anything.
Builds
Reply 10581 of 31833, by brostenen
Today I began building a Kickstart relocator, because the 2-in-1 kickrom-switcher, will not fit when using the CPU relocator that I use with the TF-530 accelerator. The first relocator that I build, was too thick and the keyboard will not fit. So I soldered a second one. It is all trial and error when doing something homemade.
This is the first one that I did. Ribbon cable and because the wires were under the board, and I had to isolate it from shortening out. Wich made it too high. Anyway... I did a second more slim one after this failure.
The attachment 01.jpg is no longer available
The second one, were I used an old harddrive ribbon cable and soldered it straight onto a socket's pins. Then I isolated it from shortening. It just takes a lot of time, soldering 40 wires this way.
Both relocators are not tested with a power on in the Amiga, yet a test with the multimeter on continuity, show no errors during build. Too late to test it all (it is after midnight), as I have to clean the table after all the trash. Hopefully the slim version kickrom relocator will work.
The attachment 02.jpg is no longer available
The attachment 03.jpg is no longer available
The attachment 04.jpg is no longer available
The attachment 05.jpg is no longer available
Reply 10582 of 31833, by luckybob
its a creative product. The answer is almost always YES.
Reply 10583 of 31833, by ultra_code
That's a semi-valid reason. 😀
Why would I want it? Also, is it a good product?
Builds
Reply 10584 of 31833, by luckybob
find out for yourself.
if you don't like it or have a use for it, drop it on ebay and someone will want it. The last ones sold for ~$30, so the likelihood of breaking even is excellent. Plus you will have had some fun with it.
ITS FREE FUN!!!
Reply 10585 of 31833, by cyclone3d
Tested some stuff I recently aquired.
1. VLB ATI Mach 32 - 2MB VRAM version. Also have a 2MB DRAM version.
2. 8GB CF card - supposedly PNY but not branding on them because they came from some OEM system. Had to use my Windows 10 machine to delete all the partitions before it would partition with fdisk on my DX4 system.
3. Keytronics AT and maybe XT keyboard. One version of this keyboard had an actual XT/ AT Enhanced/XT switch. This one the hole for the switch is there, but no switch. Will have to text with an XT machine to see if this one auto-senses or is just an AT keyboard.
Modified the non-stock heatsink that came on a Hecules 3d Prophet 4500 AGP video card (Kyro II) so the mounting holes lined up enough to actually work... When I got it, it just had some double sided tape on there that of course had failed. Also found that there were a couple SMD capacitors missing so I replaced them with slightly larger size ones I salvaged form a dead card. Next step is to test the card to see if it actually works.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 10586 of 31833, by brostenen
Well...
The relocators have too long ribbon cable, so there is no way they make decent contact when the machine tries to talk to them. Oh well.... Back to the drawing board. 😁
Reply 10587 of 31833, by Turbo ->
Decided to give my shelf a little break and moved about 50kg of HDD's and CD-roms to a more convenient and safe location: on the floor. I previously bought some plastic boxes, castor wheels and boards, which I put together.
Reply 10588 of 31833, by slivercr
Just browsing Vogons after a looooong hiatus, trying to catch up with the happenings.
So far I've read about the great PPro haul, anything else I shouldn't miss?
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 10589 of 31833, by xjas
This isn't "today", but rather "multiple hours last night when I should have been in bed." I made a spreadsheet that tracks the names of all my PCs, after I discovered I'd accidentally re-used the same name on three different machines. Because clearly that was a productive use of my time.
You can peruse the sheet if you want, or laugh at my senseless pedantry here:
https://docs.google.com/spreadsheets/d/1xqEtb … dit?usp=sharing
For reference, only machines that go on my network or have permanent renameable local storage (i.e. a HDD volume label) get names. Phones don't, because I can't be bothered, but I think my one Android tablet might have a name. Shame I can't find the damn thing.
Reply 10591 of 31833, by liqmat
cj_reha wrote:
Organized my bedroom/workshop. When you have a lot of stuff and limited space knowledge of how to cram stuff is essential. 😵
My mommy said I can come over to play at your house!
Reply 10592 of 31833, by luckybob
Gotta love the John Deer curtains.
Reply 10593 of 31833, by andrewreader
Also, question: Has any one had any experience with the Creative Extigy external USB sound device? I saw one at that same buy-se […]
Yes! I had one when they first came out. It depends what you want from it.
It has a plethora of inputs and outputs.
It connects to 5.1 speaker systems.
It had good software with all the EAX effects.
It can ups 2 channel audio to 5.1 audio.
Reply 10594 of 31833, by dionb
Yesterday evening fellow Vogon Thandor came over for a few beers and to pick up a big pile of stuff (I'm a city slicker, he has a whole barn to play in). We also had a bash at some boards I hadn't been able to get working. A nice little 386DX-40 board with VLB and So1 LIF that looked good at first sight but refused to do anything turned out to have horrendous corrosion from a leaked battery on the reverse. We stopped counting after ten dead traces, and it looked like it had seeped deep into the PCB. Total loss.
However these two were pleasant surprises:
On the left is a NIB EISA+VLB board I'd had for some time, had never been able to get even close to booting, but didn't want to give up on because rather impressive. Turns out it has two issues at present:
1) the VLB slot seems to short something out (as in PSU doesn't even power up when it's populated). Stick an ISA card in and that goes away though.
2) RAM... normally you fill bank 0 first. This board doesn't even start POST if bank 1 isn't populated. Once you do that. it's happily alive 😕
Still need to figure out what's going on with the VLB slot, and then there's that RTC - dead of course, and not only soldered but also located snugly between various other high components. Still, even now, it's alive!
On the right is a socketed 386/486 board with VLB. I'd written it off due to what looked like bad corrosion and not immediately booting when I tried it, but turns out the corrosion was mainly superficial, and there are mercifully few traces in the affected area. Also, the "light" in LIF is a misnomer. After having had some trouble extracting the 486 from another board's LIF socket, I was adamant we shouldn't press the CPU too hard. Thandor insisted though and I was glad he did - after a good hard press, it came to life. Still not entirely happily booting DOS, but definitely worth spending some more time on.
Reply 10595 of 31833, by Mister Xiado
it's getting to the point where this is all I do anymore.
Reply 10596 of 31833, by Turbo ->
Made a safety copy of my original Windows 95 floppies, using Winimage.
Reply 10598 of 31833, by brostenen
Did a blog post.... 😀
Reply 10599 of 31833, by SpectriaForce
Managed to migrate save (two .HUD and one .SAV file) and game data from NFS Porsche on one pc to another pc and getting it to work right. It didn't work right at first because I got errors in the form of 'unable to open file x' with a reference to a code line, but I could force it to run ignoring the errors. It turned out that all I had to do was to unselect 'read only' in properties of the files which the game couldn't open (or write to?). Now the game seems to run error free and it saves me tons of time completing evolution mode with all cars 😀
The attachment 687845648789.jpg is no longer available
