Reply 26580 of 58436, by MMaximus
Bought this lot yesterday from a hoarder: 8 desktops PCs ranging from Socket 7 to Pentium 4. 3 old keyboards, loads of floppies and 30-pin and 72-pin RAM sticks.
I might resell most of these locally without even cleaning them as It's not really an era I'm passionate about and I don't have so much time to spend on them, but of course I'll look if there are any interesting cards in them first...
ZpJ76iOl.jpg?2
Hard Disk Sounds
Reply 26581 of 58436, by Cyrix200+
*snip*
That 'EGT Cirius 3000' looks interesting.
1982 to 2001
Reply 26582 of 58436, by oeuvre
oh man, that vectra and presario! quick, build a pair o' threadrippers in them!
Reply 26583 of 58436, by MMaximus
That's the odd one. Looks like a proprietary system designed for telecommunications (Telex, Teletex, Fax). I don't know what's in there yet or if it would be even possible to turn it into a DOS or windows machine.
I have absolutely no interest for these OEM systems so I'm not sure what to do with them at this stage 😕 Actually everytime I see a case where the 3.5" floppy drive or CD-Rom drive is hidden behind a weird proprietary bezel I run away 🤣
Hard Disk Sounds
Reply 26584 of 58436, by liqmat
You must find a way! That's a cool looking chassis.
Reply 26585 of 58436, by oeuvre
damn if you were in the US I;d pay for shipping for one of them
Reply 26586 of 58436, by brostenen
I bought a scandoubler....
http://wiki.icomp.de/wiki/Indivision_ECS_V2
Reply 26587 of 58436, by liqmat
brostenen wrote:
Is that the one that's about $100 and you can stack two of them for dual monitor? I installed one of those in my Amiga 2000 before sending it off to a museum which now uses that machine to test Amiga games they get in. I had a rev 4.1 board, which is fine, but I had to modify one of the caps so the board would fit. Great product BTW.
The Amiga 2000 I modified right before it was sent off to the museum. 2MB RAM, Indivision ECS Scandoubler/Flicker Fixer and a Lotharek HXC Rev F SD drive. Keeping it classic.
The attachment Amiga2000.jpg is no longer available
Reply 26588 of 58436, by wiretap
Ebay coupon for 15% off today.. ended up scoring a few items.
- Doom 2 CD-ROM version in big box ($39)
- Duke Nukem 3D Caribbean "Life's a Beach" in big box ($63)
- Pentium MMX machine for $67 shipped.. I was mostly interested in the case for my 486 build, since these are somewhat hard to come by for under $100. I have a MHz display on hand that I'll be putting in it, if it doesn't have one already. Pics:
My Github
Circuit Board Repair Manuals
Reply 26589 of 58436, by ph4nt0m
appiah4 wrote:
It has apparently suffered a broken cap (that apparently also tore out the solder pad) at some point, and someone fixed it like […]
It has apparently suffered a broken cap (that apparently also tore out the solder pad) at some point, and someone fixed it like this:
Not pretty but seller assures me it works, and if it really does I'm OK with it. I will go ahead and test it tonight.
It's possible to restore a torn solder pad by pulling one from a dead card and gluing it to the PCB with silicone sealant. Then solder everything carefully and no one will notice.
My Active Sales on CPU-World
Reply 26590 of 58436, by Cyrix200+
<snip>
[url=https://imgur.com/jzHjmLw][img]http://i.imgur.com/jzHjmLwh.jpg[/img][/url]
<snip>[/quote]
Looks like an Asus P55T2P4. Nice!
1982 to 2001
Reply 26591 of 58436, by debs3759
SW-SSG wrote:
Merovign wrote:
Okay this one has an *IBM* DX4-100 on it. That's nice, I had an IBM SLC 166 back in the day.
The MB looks like a PC Chips, albeit the cache might actually be real (it's at least socketed and doesn't have "WRITE BACK" printed on it). The CPU is either a Cyrix manufactured and branded by IBM or an Intel DX4 manufactured and branded by IBM; I'm still fuzzy on which it is with the 486 chips...
The CPU is Cyrix compatible.
Reply 26592 of 58436, by wiretap
Cyrix200+ wrote:
<snip>
<snip>[/quote]
Looks like an Asus P55T2P4. Nice![/quote]
Yes, it is. Dead Dallas RTC battery, but that's an easy fix. :cool:
My Github
Reply 26593 of 58436, by Cyrix200+
wiretap wrote:
Cyrix200+ wrote:
<snip>
<snip>[/quote]
Yes, it is. Dead Dallas RTC battery, but that's an easy fix. :cool:[/quote]
Yeah, it's easy to reach!
1982 to 2001
Reply 26594 of 58436, by xjas
Okay, weird. I sold that exact board (unpopulated - no CPU, RAM, or cards) in that exact case to a local guy a couple years ago. I'm on the west coast, but things do move around... Would be pretty neat if it's the same system!
Where is it getting shipped from?
Reply 26595 of 58436, by brostenen
liqmat wrote:
Is that the one that's about $100 and you can stack two of them for dual monitor? I installed one of those in my Amiga 2000 befo […]
It is the version 2 of that scandoubler. Same company (Individual). On paper they have made it better, and they did not lie, when they told that would cost the same as the original version. I have no clue on, if it can be stacked and give dual monitor output. I am going to use my IndevisionECS V2 in my Amiga600. It is a recapped machine, and I am going to keep it classic as well. To a degree that is. I have the A604n ram upgrade installed, in order to have the IndevisionECS-V2 working. And it will allow me to use the RapidRoad USB upgrade, if I find some kind of way to install the USB-Ports somewere nice in the case. If I choose the USB upgrade, then I will be upgrading my machine to the new 3.1.4 AmigaOS released a couple of month's ago.
Nice 2000 by the way. I totally get, if they are happy with it. It must have been hard to let it go.
Reply 26596 of 58436, by wiretap
West Virginia is where it says it ships from.
My Github
Reply 26597 of 58436, by liqmat
A huge find for me today, literally. This black tower of power has all the bells and whistles for its time. I will be cleaning this sweetheart up over the next couple of weeks piece by piece. A physicist from a university used to own this beast, I was told, and I found it in an old hardware shop. I wont say what I paid, but it wasn't cheap nor was it too expensive either. Once I have it all cleaned up this will be my main software imaging system and software archive box.
The attachment black_tower_1.JPG is no longer available
The attachment black_tower_2.JPG is no longer available
Initial turn on reveals the A: drive (3½") pulls up just fine, but B: (5¼") doesn't seem to want to cooperate. Haven't had a chance to play around too much though.
The attachment black_tower_3.JPG is no longer available
The attachment black_tower_4.JPG is no longer available
The attachment black_tower_5.JPG is no longer available
Reply 26598 of 58436, by liqmat
Let's look inside.
The attachment black_tower_6.JPG is no longer available
The attachment black_tower_7.JPG is no longer available
A nice mammoth full length EISA SCSI controller and a row of 16 4MB memory sticks for a whopping 64MB of RAM.
The attachment black_tower_8.JPG is no longer available
Another mammoth ISA card. A dual line modem.
The attachment black_tower_9.JPG is no longer available
A sweet tasting Kingston Turbochip.
The attachment black_tower_10.JPG is no longer available
Reply 26599 of 58436, by SW-SSG
Oooo, "Full AT" bigtower... in black! With matching SCSI HDD bay and dual-floppy!
I wonder why the owner put a floppy disk label on that HDD...
EDIT: Weitek FPU (?), too... I don't want to know how expensive that entire machine was when it was brand new.
