Reply 60 of 83, by SirNickity
Congrats! 😁 Just remember, if it were easy, it wouldn't be so rewarding.
Reply 61 of 83, by novasilisko
Oh yes, I forgot a picture of the system so far. I decided it needed a little more life to it. Believe it or not, I do intend to cable manage it at some point and get everything routed nice and neat, once it's more finalized. If that ever happens.
The first thing you probably noticed is that the VGA card has no bracket. It came with one, but it's oddly shaped and seems to have been bent out of shape then back into shape, and doesn't quite fit in the case. I intend to try 3d-printing a new one that fits better, so we will see how that goes.
Yes... we all tell ourselves that...
Phoenix / The Disasterpiece
Processor: Am386DX-40 | Memory: 20 MB | Graphics: Trident TVGA9000B | Sound: TBD | Era: No
Reply 62 of 83, by dkarguth
Nope, the first thing I noticed is the absolutely delightful plastic plant that is living in your case. Please promise to never remove it. 🤣
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 64 of 83, by novasilisko
I don't believe I could even if I wanted to (which I don't intend to). I originally did intend it to be temporary, but I discovered that double-sided tape REALLY likes to bond to:
- Computer cases
- Aquarium plants
Anonymous Coward wrote:
You should put some astroturf in there for good measure.
Honestly, looking at this I've had some terrible ideas about making some sort of detailed diorama featuring a functioning computer embedded (maybe not literally embedded) in it. Some HO scale science lab or a lunar archaeological team excavating a 486. Why yes, I do question the rationality of my own motivations sometimes.
Reply 65 of 83, by dkarguth
Please tell me your case has a transparent side panel so you will be able to see the plant when it's finished. That would make my day. Also, it wouldn't be a real PC build if you didn't add RGB lighting to the plant. I should design an ISA RGB lighting controller just for kicks and giggles when I'm bored some weekend.
Keep up the good work!
Reply 66 of 83, by novasilisko
I've actually done some thought on a lighting controller that would interface with serial using a microcontroller (just something quick and dirty using arduino libs and some level shifters, send it a message like "PULSE 5 255,128,96") so it can operate independently after you tell it what it should be doing. But an ISA interface version of the same thing would be wonderfully silly.
I've done some cable management since the last picture but still want to make a few other changes before another portrait session. Might try printing the new VGA card bracket, although I really need to give my printer some TLC... I think I've got some rollers too tight because it sounds a bit uncomfortable when moving in certain ways.
Reply 67 of 83, by chrismeyer6
This is a really fun build thread I'm really looking forward to seeing what you do next.
Reply 68 of 83, by novasilisko
Behold, cable management! It's... an improvement!
Once I work out whether or not the floppy controller on this card works (and accordingly, whether or not I need to swap it out), I think I'm going to connect the drive module with an extension cable, then mount it to some sort of 3d-printed outrigger sticking out from the card, so it isn't awkwardly protruding vertically and blocking two additional slots...
Reply 69 of 83, by novasilisko
I've been having some more bad ideas. After the hassle with the floppy drive (which I still can't pin down), I've been leaning toward getting one of those USB to floppy emulators instead. But that leaves me with a problem - what if I have any floppy disks I want to actually use?
Meanwhile, I discovered the following device on ebay:
(10/10 classiest watermark 2019 award)
It's basically a USB to floppy adapter, without the drive. You can attach it to any drive and it will be treated as a USB device. Naturally, that had me intrigued, so I decided to order one. Only available from china though, so I'm still waiting on it.
Here comes the bad idea.
I can take this device, plug it into a known working floppy drive, insert that drive into my modern PC with the internal USB header, and use that to make disk images of all the floppy disks I want. Then I can feed those images to my 386 with a floppy emulator. And there's nothing stopping me from swapping the real drive over to the 386 for the real experience, or if there's any compatibility issues, which you can't do with one any of the random external floppy drives out there (like the one I have, which is already making concerning swishing noises when reading any disk)
The only sticking point (apart from whether or not the adapter even works) is connecting it internally, but there are plenty of little adapters that can connect from an internal USB 2.0 header to a USB-A receptacle, and I in fact have one already, in the form of an expansion slot insert with two USB ports. I can just unscrew the bracket and tie up the cable slack and plug the drive in internally that way.
I do hope this works. Having a 2017 spec PC with a working floppy drive is a stupid, delightful dream.
Reply 70 of 83, by dkarguth
What I really wonder is if that device would work with a 5.25" drive with an adapter. I haven't been able to find a USB 5.25 inch floppy drive yet.
Reply 71 of 83, by novasilisko
If I can get my hands on one and an adapter for 5.25" from a 34-pin connector, I'm definitely gonna try that. I also want to try to dissect that off-the-shelf USB floppy drive I mentioned and see if there's any sort of recognizable connection inside... even if it's some weird type of connector, I can't help but wonder if it's using the same interface, and accordingly, if the USB adapter module could be extracted from it.
Reply 72 of 83, by Old PC Hunter
I've got a 386 DX 40 board that looks similar to this, but it has a soldered 386 DX 40 and slight differences. I'll post pictures when I can.
Set up retro boxes:
DOS:286 10 MHZ/ET4000AX1MB/270 MB HDD/4 MB RAM/Adlib/80287 XL
W98:P2 450/Radeon 7000 64 MB/23 GB HDD/SB 16 clone/384 MB RAM
XP:ATHLON X2 6000+/2 GB RAM/Radeon X1900XTX/2x120 GB SSD/1x160 GB and 1x250 GB 7.2k HDD's/ECS A740 GM-M/SB X-Fi
Reply 73 of 83, by dkarguth
from the looks of it, you should be able to just attach a double-length dual row header and just connect a normal floppy cable on there. I may be wrong there however, so maybe not. I guess you'd just have to match up pin 1 on everything and then you'd have the correct adapter. I doubt the thing would recognize the 5.25" drive, though, as it is probably built as cheaply with as little features as possible.
Reply 74 of 83, by novasilisko
Yeah... I'm not holding out hope, but I definitely aim to find out.
Reply 75 of 83, by SirNickity
AFAIK, there's no way for a floppy controller to identify the type of drive, and I would imagine USB adapters would need to know what kind of drive it is to pass that on to the OS. Ordinarily you would provide that detail at the BIOS setup screen, but that doesn't apply when attaching via USB. I.e., my barely-educated guess is that it is hard-coded to identify itself as a 3.5" 1.44MB floppy drive, and unless there's a way to tell it otherwise (jumper, solder pad, etc.), it would probably not (properly) support a 5.25" 1.2MB drive.
I have a USB external drive that I disassembled once. It does not use the standard floppy interface internally -- not even a common laptop floppy ribbon (since it's a small form factor drive). It's clearly designed from the get-go to be a USB drive. This does have one benefit, though: It's fast. 2x the speed of a normal floppy drive. Since this speed is set by both the disk RPM and the controller data link speed, you can't just turbo a standard drive. It has to be an all-in-one drive + controller that is designed to run at a higher / different speed.
Reply 77 of 83, by SirNickity
Well that's curious. I didn't see any DIP-24 slots on your motherboard.
Reply 78 of 83, by novasilisko
And some other bits. This time, a prototype 8-bit ISA breakout board for making custom cards if so desired, without needing a whole card-sized PCB. Can just link it to some breadboards out of the machine or whatever.
In this case, I am giving serious, dangerous thought to the idea of constructing my own Adlib-compatible sound card. Hence the impulse-purchased YM3812.
Reply 79 of 83, by appiah4
Having an adlib clone PCB printed would probably not have been that much more expensive.. Of course, if that's the kind of project you want to undertake, by all means.
