First post, by metricmoose
I've been cleaning up an old laptop I found, a HyperData FT-6000EA. It's hard to find any information about this computer, but it seems like one of those generic models that was rebadged by a few different companies, the original company possibly being "Featron". It has a Pentium 1, 32MB EDO RAM, floppy drive and a 800x600 LCD. So far, I've replaced the old 1GB HDD with a CF card and got Windows 95 installed and running nicely. I ordered a new CMOS battery since the old one leaked, but didn't cause any damage. Besides that, it's in excellent shape!
One major problem was that this laptop sat on a shelf for close to 20 years, so the main battery is obviously toast. Windows 95 showed it as fully charged, but unplugging it caused the screen to instantly go black, the speaker made some nasty clicking sounds and just barely held on. I also saw some white crystals near the battery contacts, so it must have leaked a bit. I could barely find proof that this computer existed, let alone replacement parts, so I decided to take it apart to see if rebuilding it was possible.
https://imgur.com/a/Wb2Oeh9
After scoring the seam and using a small metal spudger, the two halves of the battery case came apart pretty easily! It turns out that this was a dumb battery, with ten 1.2V 3.5Ah Ni-Mh batteries connected in series. There's what appears to be a temperature sensor and a thermal fuse. Also, lots of corrosion... Looking up the battery cell size on Digikey, I found some compatible replacements but an order of ten would set me back about $118, which is a bit more than I'm willing to spend on this weird generic thing.
What I'm hoping to do is kind of silly, and that's using regular AA 1.2V 2.6Ah batteries to rebuild the battery. The capacity is going to be significantly less, but these AmazonBasics AA Ni-Mh batteries will only cost about $26CAD for a pack of eight. Since the AA batteries are about 11mm wide and 48mm long compared to the original 14mm wide and 64mm long cells, I should even have room for plastic AA holders to avoid having to solder directly to the batteries (I don't have a spot welder, just a regular Hakko FX-888D soldering iron).
Could this actually end up working safely? I imagine the charging circuitry in the laptop would be monitoring the voltage level, so it may not care about the reduced capacity besides feeding bad time remaining estimates to Windows.
Reply 1 of 8, by Nprod
You can definitely do it, but the price for 4/3A NIMH batteries isn't too different from AA's when you go for the cheapest compared to original Sanyos. You can get a 10-pack of generic 4/3As from china for 22$, but you have to understand that they have a tendency to lie unscrupulously about the capacity. If it says 3800mah it's likely to be something like 1400-2000mah actual, and i wouldn't be surprised if Amazon Basics ones are the same.
https://www.aliexpress.com/item/10Pcs-1-2v-4- … 2412555871.html
As for the charging circuitry i doubt it's smart enough to keep track of capacity, after all the batteries are going to lose their capacity over time through daily use.
Reply 2 of 8, by mdog69
The problem with industrial sized batteries is that you need to find someway of connecting them together - soldering tagged batteries takes up space in the pack, so you end up having to spot weld.
I've got a NiMH laptop "on hold", with the battery pack split apart - 8 off 4/3AA batteries. My game plan is to replace with two 4xAA holders, initially using some spare/knackered "2500mAh more like 1500mAh mate" cells I have lying around, and if it works, I'll look out for some low self discharge cells - I would expect to pay about £10 (GBP) including shipping (=18CAD/13USD).
I've already worked out the diagram for the builtin charger controller - matches the data sheet, but it looks as if the battery pack itself has reversed polarity, so I decided to "reprioritise" and park it for the time being. (This laptop had a LiIon/NiMH option - the charger controller being built into the battery pack).
Reply 3 of 8, by Nprod
Soldering them together directly by the leads is not impossible, i've done it for a cordless drill's battery pack, using lead-free solder even. What you do is you rough up the surface with sandpaper first, add a drop of flux and then solder on a bead using a large tip on the iron (holding it on no longer than 2-3 seconds). Using AA battery holders makes future swaps easier but that's about it. The easiest thing to do is get a pre-packaged 9.6V bundle (or a 12V one in metricmoose's case) for an RC car, they come with a convenient connector too.
Reply 4 of 8, by mdog69
That's ok for side by side connections between two batteries located "II" but I was thinking about batteries in line "--" in a cramped box where any strap between batteries needs to be within the diameter of the battery and as thin as possible - the only additional thickness with a spot welded strap is caused by the thickness of the bend. With a pair of batteries with prewelded tags, the thickness is determined by the solder blob holding the two tags together, and with untagged cells you have two solder blobs.
It might only add a couple of millimetres, but combine that with the fact that you could have 2mm tolerance in length between two batteries from different manufacturers, and you could end up running out of space.
Reply 5 of 8, by metricmoose
Thanks! I didn't think to check Aliexpress, unfortunately it looks like the shipping is going to be $35 on those batteries and I couldn't find a better deal than that. I also dug around Aliexpress some more and found a pre-wrapped 12V Ni-MH pack, but it was listed as only 1.8Ah, which wasn't too inspiring. So I ended up buying a 10xAA holder for three bucks on eBay and I'll order the 8 pack of AmazonBasics 2.4Ah AAs. The dimensions on the pack seem just about right, though the height might be cutting it close. I guess I'll find soon enough!
Reply 7 of 8, by Nprod
Oh yeah, inline is going to be difficult... Did the original pack have them spot-welded end to end?
Why an 8-pack, don't you need 10 of them?
Hint: Ikea rechargeables are supposed to be relabeled eneloops.
Neat! I'll have to remember to look for them next time i'm there.
Reply 8 of 8, by retardware
As Nprod said, just solder the batteries.
The crucial thing is to keep the actual heating as short as possible and the solder blob placed and sized in a way it does not disturb.
An 1mm solder blob at about 1/4 diameter into the inside of the battery is best, where you can solder at the side of the battery "pin". Just as large as necessary for a good connection and placed that it won't increase the length of the battery chain.
Exercise this using dead batteries. You must be quick. 2-3 seconds are sufficient to damage/degrade batteries, so hone your skill that you can make it in less than one second. (Hint: Iron must be hot, I have set it to 450 degs C, and tin must be leaded and have good quality flux core. Soldering station must have some minimum power too, maybe 50+ watts)
