First post, by tayyare
- Oldbie
I recently grabbed that Cooler Master Cavalier 2 CAV-T02 case/chassis.
It has a analog VU meter but available information about it is very slim to say the least. It supposed to come with a bracket that should somehow connect it to a souncard's or motherboard's speaker jack, but it is missing.
I found a low res picture of the accesory, and a manual for similar but different case
http://www.google.com.tr/url?sa=t&rct=j&q=&es … 9LSOR_HfzL1lF7t
And here is the picture showing VU meter PCB and where the input should go (3 pin male connector at he left, just under the power molex):
What do you think? If I just somehow connect the speaker out from the board (Left channel, right channel, ground) driectly to this, will it work?
Or this mising black box/backplate combo is not a simple breakout box, but has a PCB hidden inside that supposed to make some kind of a conversion?
Thanks in advance 😊
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
