meljor wrote:Not even close.... my k6-3+ clocked at 550-600mhz is in games about equal to a p2-300 to 350mhz. In normal apps they can be pretty equal and actually sometimes a bit faster. in games they can't hold a candle. Clock for clock in games they are about as fast as the pentium1 mmx.
The k6-3 is up to 20% faster compared to the k6-2, depending a bit on the software/game. k6-2+ around 10%.
But again, it depends op *which* games.
Your figures here sound like the Quake 1 engine, which is FPU-intensive - and it's well-known that the K6 can't hold a candle to the P6:
However a lot of period games were more ALU-intensive, and there the difference is much smaller, with the full-speed caches of the K6Plus CPUs compentating to the point where they can equal clock-for-clock Deschutes/Katmai scores.
See eg:
And then you had things that actually used 3DNow, like Quake 2, which would give K6 an advantage.
Bottom line: as tpowell.ca said, you simply can't compare architecturally different CPUs in this way. There is no absolute "better", only "better at ...". You need to look on a per-application, per architecture basis.
