Reply 28180 of 58857, by Intel486dx33
wrote:wrote:Twins. Baby ATX , Super Socket 7's FIC VA-503+’s with AMD K6 CPU’s. […]
Twins.
FIC VA-503+’s with AMD K6 CPU’s.These should work great for over locking an AMD k5-3+-450mhz to 550mhz.
Maybe even try for 600Mhz or a bit higher. For the 6x multipler, set the jumpers to 2x.
I think those boards should also have a few settings that are above 100Mhz fsb if I remember correctly.
I think I will try one out over the weekend. See if I can achieve 550mhz.
Motherboard settings read I can set to up to ( 100, 112, or 124mhz x 5.5 )
I don’t know why they allow these motherboards to clock so high if the K6 max’s out at 500mhz. ?
