3d rage pro driver
First post, by cnpr
hello, I have ati 3d rage pro pci card that i can't seem to find the driver. does anyone know where i can find a windows 95 driver
Reply 1 of 4, by TheMLGladiator
The win98 drivers can still be downloaded from AMD. However, they require directx 8.1 to work correctly. I found the older win95 compatible driver on archive.org from ati.com. Im going to try to find it again.
Reply 2 of 4, by TheMLGladiator
https://web.archive.org/web/19980128132719/ht … 3drage_pro.html
Above is a link to the oldest version of the driver for win95. Newer versions can be found by using the timeline at the top of the page. Newer versions may be more stable, but may also require a directx update.
EDIT: All drivers you should need should be in the link below (it also has the old drivers from above)
https://web.archive.org/web/20001018122748/ht … 3drage_pro.html
Reply 3 of 4, by Stiletto
Made me think of:
https://gona.mactar.hu/ATI_3D_CIF/
do the Fandango!" - Queen
Stiletto
Reply 4 of 4, by TheMLGladiator
That's actually very cool!
EDIT: Looks like I actually needed that link. I like to use a Rage Pro Turbo under Windows 98, mainly for compatibility. They really aren't as bad as many people say they are. It's really just about finding the right drivers/directx versions.
