Reply 28760 of 53278, by Deunan
wrote:Today, I received a completely broken motherboard! The one motherboard I've been seeking out for a few months because I have a special adapter, for this very specific motherboard. That the seller chose to package in just bubblewrap, going across the oceans, hundreds of miles, just arrive looking like this. Doesn't work at all...
That doesn't look too bad, there shouldn't be anything there to cause the mobo not to work unless the inside layers copper got exposed and is shorting to something. If you can't return it then I'd suggest to file this corner down a bit with sandpaper. Then you can apply some clear coating to prevent further shorts and oxidation from creeping in.
