KVM Switches
Reply 20 of 22, by McBierle
So, i finished this for now. I got myself a rs232 switch for the mouse.
166.58 KiB
It is working with my momentary setup. Just have to switch the mouse before booting/starting windows.
Reply 21 of 22, by kaputnik
chinny22 wrote:
One thing I recommend is getting KVM's that use standard cables. my no name 4 port KVM is good but uses a serial port connecter […]
my no name 4 port KVM is good but uses a serial port connecter on the KVM side so good luck if I losses a cable.
Where as my 8 port Compaq and most enterprise stuff has the vga and 2 ps2 connecters for each input, so you can buy the kvm cables, or just use a standard vga cable and ps2 extension cables.
Audio really limits your options, I just run audio extension cables from the soundcard up to the KVM and manually plug the speakers into whichever I need
Since I don't need to really switch between different sound sources - never ever using more than one retro computer at once - I'm using a simple homemade passive mixer together with the non audio capable KVM switch my retro computers share the other peripherals through. Posted about it here. Works like a charm, and is really convenient 😀
Except for the extra channels, it's electrically identical to this schematic, using 2k2 resistors. Would also guess something equivalent could be ebayed at a reasonable price if you're not up to some DIY 😀
Edit: the tutorial that schematic came from might be useful too, can be found here.
Reply 22 of 22, by chinny22
kaputnik wrote:
Since I don't need to really switch between different sound sources - never ever using more than one retro computer at once - I' […]
I like it! Basically the same thing but much more tidy, thanks for the idea 😀
