First post, by Deksor
- l33t
This will be a similar topic to this one but I'm making a different topic because the source is totally different, and there are enough boards for a topic on its own anyways.
All these boards were given to me by MMaximus, many thanks to him !
So the first step is going to be to identify the board itself and to identify the fault(s)
Board #1 :
LPX form factor, unknown manufacturer, untested
Board #2 :
LPX form factor, unknown manufacturer, untested, no battery, no bios chips, corroded
Board #3 :
Baby AT form factor, unknown manufacturer, no battery, tested : POST card gives some activity but no POST. Some resistor network seem to have been removed.
Board #4 :
Baby AT form factor, unknown manufacturer, no battery, no bios chip, no crystal, tested : POST card gives nothing (I tried a Quartz but I don't know if it works or not because the CPU don't really heat up and the quartz is loose. Also I tried a random bios chip so it may just be incompatible)
Board #5 :
Baby AT form factor, unknown manufacturer, no battery, untested, corroded
Board #6 :
Baby AT form factor, Suntac motherboard, no battery, untested, no bios chips
Board #7 :
Baby AT form factor, unknown manufacturer, no battery, untested, no bios chips, corroded
Board #8 :
Baby AT form factor, unknown manufacturer, no battery, untested, no KBC
Board #9 :
Board #10 :
Unknown form factor, unknown manufacturer, old battery to be removed, (no KBC ?). Not sure if I'll bother with that one actually.
Board #11 :
Baby AT form factor, suntac motherboard, no battery
Board #12 :
Baby AT form factor, unknown manufacturer, no battery, corroded
So to summarize, 5 boards have corrosion, not too bad though, most have a unknown manufacturer/name for now (if you know anything, you'd be of great help 😁) and 4 are missing their bios chip.
Also most of them use SIPP ram and/or RAM chips. I have NO SIPP memory sticks (but I can swap them for SIMM slots) and only few RAM chips, and none are bigger than 256kilobits so this is going to be an issue ...
Anyways, it's identification/testing time !
