Reply 30460 of 58451, by jaZz_KCS
vutt wrote:
While I have Serdaco X3MB which should be Sound Canvas replica I felt I need little-bit more bling and alternate GM sound. […]
So I bought this one off the ebay.
"Thanks" Hermes/DPD for nice delivery across Europe. 😒 I managed to straighten them up. Then checked for short with multimeter and plugged into wall (yeah slightly suicidal I know).
It worked, but I measured over 17V on output plug. Well it should be 12V. No way I'm going to put that into my precious vintage midi module.
So I found modern replacement power brick with similar output and it worked. So I'm happy.
To my amazement Monkey Island in Roland mode and MU50 in "C/M" not "XD" mode sounded quite OK. I need to test little more with various games. This C/M mode might work like limited MT-32 replacement.
17V seems still alright keeping in mind that the voltage will drop severely when on load.
9V power supplies also show well beyond 12V when not under load. This is pretty normal. Albeit arguably, 17V is already a tad high. 15V would be totally fine as it will surely drop down to the vicinity of 12V when under load.
Regarding Hermes. Domestically and internationally I had very good experience with Hermes.
Reply 30461 of 58451, by Tiido
You, unloaded transformer shows much higher voltage on the output. The voltage rating shown is only with the load shown too, i.e if it is 12V 1A it gives 12V when loaded with 1A, and say 14V when only 0.5A and 10V if 1.5A. Overall it won't matter so much because the 7805 in the device will take anything from 7.5V to 20V+.
Reply 30462 of 58451, by vutt
Well I’m using 12V 6A (total overkill) power brick from one of those RGB led strip kits. It gives me 12,89V without load. I guess it’s down to circuit design then.
Anyways I managed to brake one of the pins on original adapter. Case looks glued so no easy repair. Also using modern adapter feels little bit safer.
Reply 30463 of 58451, by Tiido
Those are regulated power supplies, the stuff these old things come with are nothing but transformer and rectifier, no regulating elements there. All modern power supplies are switch mode things where regulation is essential part of the design (though it is possible to make a switcher without regulation, which will behave mostly same way as normal vanilla 50/60Hz transformer design).
Reply 30464 of 58451, by dionb
You win some, you lose some:
With an enter that big I thought this would be an Alps-based board. Instead it's dome-over-slider. Still, pristine NOS condition and pretty decent dye-sub PBT caps could have been worse.
Shame about the oddball vertical bar cap mounts, so no way to use the caps on other boards.
Reply 30465 of 58451, by Caluser2000
The attachment 20190929_114911[1].jpg is no longer available
The radio card is for Dos(TSR) and Windows 3.1 with software and driver disk. Just need to track down a suitable antenna/arial for it. The game card was one of those "just because" purchases. Both are ISA 8-bit cards.
Reply 30466 of 58451, by Tiido
I actually have two of these radio cards, but none of the software. It would be really great if you could upload the software somewhere, I'll be able to mirror it on my server on a permanent basis too ~
Reply 30467 of 58451, by Caluser2000
Looks like the disk has errors on it. There was a note on it he might be useful to someone. I'll try to carry out some recovery options though and see what happens. Fingers crossed. PM me were you'd like the files to go if I do manage to retrieve the software.
The attachment 20190929_153438[1].jpg is no longer available
The attachment 20190929_151738[1].jpg is no longer available
Reply 30468 of 58451, by cyclone3d
Did a bit of searching and it looks like this card was also sold under the Reveal brand.
Attached is the driver/software disk. Hopefully this is the correct one.
The attachment revealfm.zip is no longer available
Same version as above according to a file inside the zip, but this one has the DOS tuner program included.
Readme says is works for Windows 3.1 - ME
The attachment Revealra300.zip is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 30469 of 58451, by Caluser2000
Found my old vcfed post from 2012 asking for the manual. Looks like Agent Orenge did send them but have no idea were they are. I'll have to do some digging. http://www.vcfed.org/forum/showthread.php?302 … t-FM-radio-card
Thanks cyclone3d they look like the Windows 95 files. There was the original win3.1/Dos disk as well with the reveal package from what I understand
pmr140.zip the radeo card driver for OS/2 is at this site http://home.clara.net/orac/os2.htm#pmradio and I've attached it here:
The attachment pmr140.zip is no longer available
Reply 30470 of 58451, by PC Hoarder Patrol
Not really my thing now tbh, and its been so long since I owned any S7 kit I wouldn't know what's what, even if I'd been actively looking, so when I got the offer of this bundle from an ex-colleague who was clearing out stuff I figured I might take a small punt on it. Picked up today in exchange for little cash, but quite a few (too many) beers 😲 😕 😀
The attachment S7_Stuff.jpg is no longer available
The attachment DFI G586IPV_C.jpg is no longer available
DFI G586IPV rev. C with 32 meg and max cache ob - seems OK with 233MHz MMX cpus + has SDRAM slot!
The attachment ECS P5HX-B v1.0.jpg is no longer available
ECS P5HX-B v1.0 with 64 meg and max cache (half ob and half with ECS-branded COAST - lacks split-plane so limited with cpus and RTC is shot, although socketed
The attachment S7_PROCSnSINKS.jpg is no longer available
Selection of cpus and heatsinks - P150, P166 and P233 MMX
Absolutely no idea what I might do with it all, but it seems decent enough.
Reply 30471 of 58451, by cyclone3d
No problem.
Did a bit more digging and found a .zip that has the DOS tuner program. The driver version is the same, 1.1, according to the file inside the .zip.
The user created readme says it works for Windows 3.1 - ME.
I have attached it to me previous reply.
YMF7x4 Guide
Reply 30472 of 58451, by respect2759
Wow that white DIN connector looks good 😎
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 30473 of 58451, by Caluser2000
cyclone3d wrote:
No problem. […]
No problem.
Awesome. Thanks again.
Reply 30474 of 58451, by lolo799
Caluser2000 wrote:
cyclone3d wrote:
No problem. […]
No problem.
Here's the Radiotrack floppy image, it has the 1.2 player for DOS and the 1.1 for Windows, it also comes with a TSR to turn the radio on and off with a key combo:
The attachment radiotrack.zip is no longer available
And the french manual:
The attachment radiofm1.jpg is no longer available
The attachment radiofm2.jpg is no longer available
Reply 30475 of 58451, by oeuvre
A CT1350b, finally! Works perfectly... just one question though, if I try to use 2 ISA sound cards (this one is set to 220, IRQ 5) it locks up at post. The other card is an Aztech from a Packard Bell. That card is PnP and has no jumpers on the board.
Reply 30476 of 58451, by derSammler
Go into the PnP configuration in the BIOS and make sure the ressources used by the Sound Blaster are reserved so that they are not assigned to PnP cards. The PnP BIOS does not know about ressources used by legacy cards. You have to tell it.
Reply 30477 of 58451, by oeuvre
The Dell BIOS has no options for PnP resources or setting any kind of IRQ resources manually.
Reply 30478 of 58451, by SpectriaForce
wiretap wrote:
Normal ATX case, normal ATX power supply, no special pinout on the ATX connector.
Thanks for letting me know.
Reply 30479 of 58451, by PcBytes
GigAHerZ wrote:
Maybe it's a non-MMX Pentium then? Would make more sense...
Some of the classic Pentiums were released in plastic packaging similar to the MMX. I have a non-MMX P166 in my stash, gotta find it sometime.
